HAPPY FEEDBACK FRIDAY! Whose up for Trivia Time w/ Tony? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 06-06-2014, 05:55 AM Thread Starter
Tony7's Avatar
Ok, gonna keep this short and sweet...because reading is over-rated...
Truck:
2002 F350 Crew Cab/Long-bed/Lariat/COMPLETELY STOCK
Plan:
Pro-comp 6.5" Suspension lift/Toyo Open Country MT 37x13.5R17/Mickey Thompson Classic III 17X9's with 0.00offset and 5inch backspacing
Application:
DD, no hauling, short commutes with a couple of long, ~1000 mile trips spread out.
Issues/comments/suggestions/pricing/websites/etc?
ok....go!
Questions of mine:
0) Nitto's or Toyo for 95% asphalt DD?
1) Is 0 offset gonna be a problem? I am running 16X7's stock ford wheels now. If I happened to run into a problem...are wheel spacers a bandade until I find a solution...if so what is a high quality brand?
2) If I measure the top of my wheel wells to the ground, I sit about 3-4 inches shorter in the front end. Will it look dumb to lift 6.5" and still not be level? What are my options as far as levelling but still lifting enough to get 37's with plenty of clearance? SEE MY AVATAR PIC.
3) Better shock options than the ES9000's to consider? ...No I don't have the money for coilovers.
4) What kind of other augmentations will I have to do lifting 6.5"s? Extending brake lines? What else?
*** I wanna have the option of running a 35" tire as well on the same wheels, I figured going less wide on a wheel width was best...also to help with clearance? Am I right on this thinking? Rather than going with a 18X10...plus I am a fan of more sidewall.
*** I really like the look of the Mickey Thompson Classic III's....if I can't use them because of the backspace/offset issue...what other makes are out there that look similar?
2002 F350 Super Duty
"Maaa!!!...The meatloaf!!!...We want it now!!!" ~ Chaz
Tony7 is offline
post #2 of 4 Old 06-06-2014, 12:33 PM
Colby's Avatar
Truck:
Plan:
Application:
ok....go!
Questions of mine:
I'd look at an all terrain unless you're dead set on a MT
0 offset and you'll be rubbing the leafs. I have -22 and still hit at full lock when off road
I've got the same lift. Your springs are just worn, once you put the lift on you'll be sitting pretty much level
mine didn't last too long. Swapped them for some procomp desert runners or something like that. They ride better in my opinion
You shouldn't need anything except what's included. The lift includes a sway bar link drop bracket and carrier bearing drop bracket for the driveshaft. My brake lines get a little tight when the axles hang free. Just keep an eye on things
the offset is going to affect your clearance (if I'm understanding you correctly). With a 9 or 10" wide rim you'll have plenty of side wall to protect your rims from curbs with 13.5" wide tires .
I'd say go look on 4wheelparts.com for a rim you like. I don't think that 0 offset is going to work.
I'm no expert but I've got a similar setup. Answers in red.
Colby
2004 F350
Pro Comp 6.5"
37" Goodyear Military Radials
16.5" Pro Comp Steels
4" MBRP
Hollowed Cat
SCT (Looney Tune)
EGR Delete
Colby is offline
post #3 of 4 Old 06-09-2014, 05:11 AM Thread Starter
Tony7's Avatar
Colby thanks! Good info here!
Tony7 is offline
post #4 of 4 Old 06-11-2014, 11:19 AM Thread Starter
Tony7's Avatar
Ok so I switched to a Pacer 164 Wheel 17X9, 8 on 170mm, and a -12 Offset...I hope this is enough to accomodate the 37's
Tony7 is offline
