Shop won't install 315's on stock dually rims - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
 1Likes
  • 1 Post By Vannnce
post #1 of 8 Old 05-30-2014, 02:35 PM Thread Starter
So Discount tire informed me that they will not install 315/75r16 on my dually rims because they're only 6.5 inches wide.
Where are you guys getting your tires installed?
tech701 is offline
post #2 of 8 Old 05-30-2014, 03:26 PM
Quoted: 57 Post(s)
Most tire shops wont install tires on rims that are outside of the tire manufacturers specs (wide or narrow). Its primarily for liability reasons and due to the fact that you wont be a happy customer due to the funky handling and poor tire wear.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 8 Old 05-30-2014, 04:15 PM Thread Starter
Would someone delete that last member's post. I did not ask nor do I care what "most" shops will or will not do.
I asked a question of dually owners who have had larger tires mounted on stock size rims where they have had this done.
Please keep all comments that do not pertain to the question asked to yourself.
tech701 is offline
post #4 of 8 Old 05-30-2014, 04:25 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Whole thread should be deleted if you aren't smart enough to find someone to install tires for you. Call Joe Blow's tire service
dhanna6powerstroke is offline
post #5 of 8 Old 05-30-2014, 05:03 PM
Vannnce's Avatar
Quoted: 13 Post(s)
jeremyfoy80 likes this.
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #6 of 8 Old 05-30-2014, 07:24 PM Thread Starter
Mr. 6..... Well said!! Consider the question cancelled
tech701 is offline
post #7 of 8 Old 06-03-2014, 11:18 AM
Tac
Quoted: 34 Post(s)
Sorry, i've read your thread and have a few questions.
The 315mm tires will go 3" outside the rim.
Wouldn't the high angle between the wheel out side and the rim don't cause a spongy drive ability in cause of the high wheel movement between tire and rim?
And make the high movment balancing the wheels impossible?
Is there enough space between the dualwheels to take the additional 6" tire wide? Aren't you afraid about rubbing the wheels against eachother?
Tac is offline
post #8 of 8 Old 06-08-2014, 05:20 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 104 Post(s)
Feedback Score: 3 reviews
Without having your location listed then your question limits the answers you could receive.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
