2000 f250 hub bearing - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 2 Old 05-25-2014, 06:17 PM Thread Starter
Anyone know if you can use the abs hub bearings in place of the non abs hub bearings? Save 200 bucks? Mine are both worn out so before i go getting the expensive ones i figured i would ask. Only difference i saw was the wire, not sure if the spacing would change for the rotor and the caliper bracket. Wheels don't seem to change truck to truck so i figured all is the same and no differences are listed for hub locks.
I'm between trucks right now
Dzlnzl is offline
post #2 of 2 Old 05-26-2014, 04:47 AM
Quoted: 780 Post(s)
Yup.
Corey@CNCFAB is offline
