Can I get some input about the pitbull rockers? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 05-16-2014, 06:57 PM Thread Starter
Hey guys!
Looking for some all around input on the pitbull rockers!
They seem awesome, look sweet, and seem decently cheap...
I do some towing, nothing long distance, will be some mudding, might try using them in the winter, and I'm hoping they last longer than 25,000 miles...
Thanks guys!
2012 6.7L F-350 4x4, XLT EC/LB SRW
Done april/2014-
Used SPARTAN dashdaq-XL, AFE intake, and 4" straight pipe exhaust (DPF deleted)...
Mods to come:
EGR delete
36x15.50R20's with -44 offset rims and a lift to accommodate!
Located in Ontario!
x-SYOTOS-x is offline
post #2 of 4 Old 05-17-2014, 07:41 AM Thread Starter
Is anyone running this tire??
I'm looking for input that you can't get from a picture of the tire!
Done april/2014-
Mods to come:
EGR delete
Located in Ontario!
post #3 of 4 Old 05-20-2014, 04:21 AM
jetjock15's Avatar
Quoted: 113 Post(s)
None of the pit bulls are rated E so nobody runs them on a SD. If you do, make sure there D rated at least, if you can only get C rated (I think the case) you need to pass as 6ply tires not going to last on a SD, and no towing or tires will heat up and come apart potentially
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 4 Old 05-20-2014, 06:59 AM
snobdds's Avatar
Quoted: 10 Post(s)
Pit bulls on a SD, now I have heard it all...
snobdds is offline
