Replaced brakes and abs is super sensitive now, brakes feel soft - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 04-26-2014, 12:57 PM Thread Starter
garyn77's Avatar
I just recently replaced my pads and rotors on my 2008 f350. Since then I have noticed that the brakes feel pretty mushy, and don't bite hard at all. It takes quite a bit of pressure to slow my truck down . The pedal does not go to the floor though, so I'm a little lost on what it could be
Also, the other day going down the highway, I got on my brakes to slow down coming into town, and I got a ton of abs feedback in the pedal. Since then this has happened a few times when I'm at speed on dry roads
Any ideas?
garyn77 is offline
post #2 of 4 Old 04-27-2014, 10:28 PM
supreme oppressor's Avatar
Try bleeding them. While in there, have a good look to make sure everything is where it should be.
2006 F350 6.0 CrewCab Fx4 - Leveled & 35" Nitto's
2002 Subaru WRX
1983 Kawasaki GPz750 with the 810 big bore kit, parked.
supreme oppressor is offline
post #3 of 4 Old 04-27-2014, 11:23 PM
I also changed all my brake pads this weekend and the same thing happened to me. I bleed all the brakes in sequence RR,LR,RF,LF and I have great pedal know.
lvniko11 is offline
post #4 of 4 Old 05-09-2014, 08:01 AM
Or in other words, furthest wheel location from the master cylinder first, working your way to the nearest one last.
David from jax
sandman2234 is offline
Tags
6.4 , abs , brakes , pads , rotors
