Where To Purchase A Splined Lug Nut Key For Early '99 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 04-18-2014, 09:39 PM Thread Starter
Austen's Avatar
Quoted: 27 Post(s)
I recently purchased an early '99 and it happens to already have splined lug nuts on, however, the key for them was lost.
I counted the number of splines and there are 6.
Would anyone know by chance where I could purchase one of these? Thanks so much!!
08/98 CCSB l 7.3 l ZF6 l TW tuned l 38R turbo l Deleted EBPV l Bellowed up-pipes l FRX l HRX l OCR l Isspro gauges l 99.5 PCM l 6637 w/ K&N intake duct l 4" MBRB straight pipe w/ axle dump l 6" suspension lift l 37" Toyo MTs l 17" KMC Strike rims l ARB front bumper l HNC rear bumper l bedliner'd rockers l Bushwacker flares l custom cab guard l '08 tailgate l PIAA fog lights l Recon tail lights l B&W hitch l air shocks l Pioneer stereo
Austen is offline
post #2 of 7 Old 04-18-2014, 11:22 PM
schlutzer's Avatar
Quoted: 18 Post(s)
http://www.amazon.com/gp/aw/d/B006UH66R8?pc_redir=1397736250&robot_redir=1
And then toss them and get regular lug nuts lol
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
The Following User Says Thank You to schlutzer For This Useful Post:
Austen (04-19-2014)
post #3 of 7 Old 04-19-2014, 08:02 AM Thread Starter
Austen's Avatar
Quoted: 27 Post(s)
Originally Posted by schlutzer View Post
6 POINT SPLINE TUNER LUG NUT KEY (1PC):Amazon:Automotive
Hey, thanks a lot!!
The link appears to be down though.
Not questioning your judgement, but are you positive this size work? I have a Tacoma that has splined nuts as well and the key for those will not work on the SD because the lugs are bigger and just want make sure that I'm getting the right one.
Thanks so much my friend.
Austen is offline
post #4 of 7 Old 04-19-2014, 08:20 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
do you have a discount tire ?
their generic wheel locks use the same splined keys on all applications just different diameters for larger sizes
I know it wouldn't stop a thief but they can upsell and give a false sense of security
anyways go ask them if u have a local Discount
I always use Gorrilla lock systems on mine
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
Austen (04-19-2014)
post #5 of 7 Old 04-19-2014, 01:54 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I dunno why the link won't work... But 6 spline lug key on Amazon will give you a bunch
If you were to order the one I linked, I would get a hold of them and ask first. There are some small diameter and large diameter keys available. In this situation I'd email them and ask.
If you can't find them locally.
Otherwise hammer a socket on them a crank them out. Would be tedious with 32 but I've had to do it before
Austen (04-19-2014)
post #6 of 7 Old 04-19-2014, 02:28 PM
sbluke55's Avatar
Quoted: 500 Post(s)
Garage
What he said^^^^
I've had luck with finding a socket that is just a little smaller than it and then hammer it on, but that is the round ones with the funny design in them like your spare tire winch key. You could try it if your in a pinch.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
Austen (04-19-2014)
post #7 of 7 Old 04-19-2014, 04:45 PM Thread Starter
Austen's Avatar
Quoted: 27 Post(s)
Thanks guys. I'll call around to some of the local tires shops and see what I can come up with.
I'll use the socket trick as a last resort.
Austen is offline
