Brake Problem - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 2 Old 04-06-2014, 09:52 AM Thread Starter
bradmowery's Avatar
Brake Problem
I have a 2001 f250 7.3 diesel. I'm having a problem with the brakes, it seems like the brakes are being applied a large percentage of the time its being driven.
The calipers are cool to the touch, the rotors are very hot after its driven even just a short distance. But sometimes they are not bad just warm but most of the time they are hot.
My ABS light is not on. I pulled the 60 amp fuse to take it out of the circuit, just to check if it was the abs module creating the problem.
Drove it for a day the rotors were warm (normal) had no brake drag, second day I drove it and I am back to the original problem of the brakes being extremely hot.
Before I had the problem I put on new rotors, new brake lining, new brakes hoses front and rear, & flushed new fluid through the system.
Also new fluid was flushed through the power steering and hydro vac system.
Does anyone have any idea what would be causing the brake drag & rotors to get extremely hot?? Could the master cylinder be part of the problem? I have been trying to figure out a solution for two months.
bradmowery is offline
post #2 of 2 Old 04-24-2014, 01:33 PM
supreme oppressor's Avatar
See if your slide pins are moving freely. The square O-rings in the caliper pull the pad away from the rotor but the other side relies on small springs so if the slides pins or where the pass slide are sticky the one side may not release fully.
2006 F350 6.0 CrewCab Fx4 - Leveled & 35" Nitto's
2002 Subaru WRX
1983 Kawasaki GPz750 with the 810 big bore kit, parked.
supreme oppressor is offline
