Rims off a 2001 on to a 2006 F250? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 03-31-2014, 10:57 AM Thread Starter
Should be no prob correct? Buddy has a set of aftermarket 20" wheels on a 2001. Want to throw them on my 2006. All net research shown they are the same bolt pattern. Can someone back me up? Thanks!
Square Grouper is offline
post #2 of 5 Old 04-02-2014, 08:59 AM
Smokin? Its broken's Avatar
i believe the size of the lug nut's pitch/thread are the only difference, that may not matter but you would def want to find out.
Smokin? Its broken is offline
post #3 of 5 Old 04-02-2014, 09:16 AM
MSTR-P's Avatar
Bolt pattern is the same; however, your '06 will require a different backspacing than a 2001.
'03 7.3 - Stock!
MSTR-P is offline
post #4 of 5 Old 04-02-2014, 10:14 AM
what is back spacing?
post #5 of 5 Old 04-02-2014, 08:20 PM
Backspacing is how old guys fit rims. Its more consistent than offset and much easier to figure out.
However, 99-04 wheels will fit fine on an 05 and up. Although the different backspace requirements will mean those wheels will stick out farther on said 05 and up. Shouldn't be more than 1 to 2 inches. Nothing major unless you don't like your tires outside of your fenders.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
