Little overwhelmed - need simple - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 03-26-2014, 06:48 PM Thread Starter
Hi guys-
Ive posted a couple times in the 7.3 forum as I currently have a 99 (completely stock) and then in the 6.4 forum as I was looking to buy a 6.4 - but changed mind and bought a 11 6.7 dually (engine has incredible stock power but not the reason for this post).
The truck has the stock steel wheels on it and 245/75/17 tires. I am getting vision crazy eight wheels (stock size) installed tomorrow - the tires are still good and will stay - for now.
My question is - with the new wheels (stock size) - what are the largest tires I can install without having to lift or level? I assume suggestions will require a spacer which Im ok with.
I occassionally pull a 43' 5th wheel tow hauler and dont want to get to high up is my rational for staying away from a lift - although a levelling kit might still be an option.
Very new to the wheel/tire customization thing.
Appreciate any help.
westy1717 is offline
post #2 of 4 Old 03-26-2014, 06:55 PM Thread Starter
Regarding current tires... the truck has 32K miles on it - looks like PO did not rotate so fronts are 70% worn - don't want to get 2 new tires tomorrow (bf goodrich rugged trail ta) and then make a decision on larger tires 2 months from now.. It is a 4X4 but Id like it sitting a little bit higher.
post #3 of 4 Old 03-26-2014, 07:36 PM
7.3pwrstrke's Avatar
My dad has a '14 6.7 and was getting tired of getting stuck in the woods with his stock tires. He wanted to go up a size and switch to a mud tire. We ended up deciding on a 285/75-17 (34x11.50) toyo MT. He hasn't gotten around to ordering them yet but we figured this size would definitely fit.
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #4 of 4 Old 03-27-2014, 04:23 PM
Boompats's Avatar
I have no clue as to what size will fit, F250's seem to be able to run 35's with no rubbing on a leveling kit, so I would assume the same for a F350. If it were me I would rotate the worn tires to the back and run them for 2 months instead of spending the money on a couple new tires just to replace them soon.
Boompats is offline
