Help With wheel width for BMF Novakanes - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 16 Old 03-21-2014, 04:54 AM Thread Starter
I'm stuck on these wheels now. Just not sure on the width to get.
They come in:
20x9 +0 offset, 5.00 BS
20x10 -19 offset, 4.75 BS.
I want the 20x10's (naturally) but want to make sure I can get away with this size with only a 2" leveling kit.
I have a 2012 F350 SRW 4x4 with fenderflares
PLEASE, Somebody tell me it will work so I can order these *****es today!
gsatroker is offline
post #2 of 16 Old 03-23-2014, 08:33 AM
Gapowerstroke's Avatar
Tire size?
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #3 of 16 Old 03-23-2014, 06:32 PM Thread Starter
35x12.5x20
post #4 of 16 Old 03-23-2014, 06:34 PM Thread Starter
I just installed a 2.5" leveling kit today. And some airbags in the rear to keep it from squatting while towing
post #5 of 16 Old 03-24-2014, 04:48 AM
I have the carli 2.5" lift and 9"wide wheels. I'm confident if I had used 10" wide wheels or less back spacing that my 35; 12.5's would rub when turning. Maybe it's different for the newer fords my gut says go with the 9"
post #6 of 16 Old 03-24-2014, 05:14 AM Thread Starter
haha, well too late for that. I got a couples messages from members on here that said the 10's would work. Might have some slight trimming to do on the front bumper bracket but should be good other than that. As soon as I get them I will post pics & results on the rubbing.
post #7 of 16 Old 03-24-2014, 05:28 AM
Ok, glad you got some info other than mine I could only give you my experience and since I have the same tires and wheels except for the wheel diameter (which doesn't matter here) I was just trying to help based on my experience. I had to pull the inner plastic wheel liner in on the rear of the front wheel well on both sides and one side still rubs slightly when turning. I did not have any problem with the bumper. Honestly I wish the lift was a 3" or that I had chose the 4.5"
post #8 of 16 Old 03-24-2014, 05:56 AM Thread Starter
Damn, making me nervous now. lol
post #9 of 16 Old 03-24-2014, 06:05 AM
Mine is an 06, I know they are similar but maybe the newer trucks are a little differen
post #10 of 16 Old 03-24-2014, 06:29 AM Thread Starter
On paper since the 10's have a lower offset that will push the tire out side the fender well more which would help it from rubbing on the inner liner. But, thens when you run more risk of rubbing the bumper bracket. Either way, I know there are tons of guys running 10's. So if I have to do a little trimming, so be it. I can't wait to put them on. Truck looks funning right now lifted with fender flares and stock, half bald tires.
