315/75/16 on stock 16" rims? Does it work? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 03-10-2014, 05:52 PM Thread Starter
Hey y'all I'm lookin to see if mt's that are 315/75/16 which is basically a 35x12.5 tire would fit on my stock 16x7 rims on my '99? On the tires websites they say it wont fit but I've heard of guys doin' it. Any opinions or pictures appreciated!
'99 F250 7.3l
- 170k miles
- Diamond Eye 5" Exhaust
- Riffraff Air Intake
- Power Hungry Performance Chip
marylandstroker is offline
post #2 of 8 Old 03-10-2014, 07:06 PM
blue99stroker's Avatar
Quoted: 283 Post(s)
guys have done it. the tire is a little ballooned but it has been done before.
blue99stroker is offline
post #3 of 8 Old 03-10-2014, 07:12 PM
Powerstroke_21's Avatar
i started a thread because I couldn't decide what size to go with, and if you go wider than 11" you need to adjust the tire pressure so the tire isn't ballooned
here's the link: tire question
I don't wanna go 315 but i was debating between 285 and 305
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #4 of 8 Old 03-11-2014, 04:06 PM
Discount Tire's Avatar
Quoted: 9 Post(s)
We would recommend that you look at the tire manufacturers web site for their approved rim width. They have approved rim widths for safety reasons.
Here is a link to Nitto's web site showing their specs:
Trail Grappler - Trail Terrain Light Truck Radial
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire is offline
post #5 of 8 Old 03-11-2014, 04:24 PM
at0075's Avatar
i wouldn't do it. the tire will be ballooned like crazy and trust me you will fill it. every time you yank the steering or hit a bump in a curve you will fill the rear end sway. i had them on MT classic 16x10s and they were still ballooned. i could be wrong but i don't even think that the 315/75r16s are quite as big as the 35x12.50. i think they are 34x11 something. someone correct me if I'm wrong
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #6 of 8 Old 04-01-2014, 09:06 PM
GeorgiaStrokin's Avatar
Quoted: 8 Post(s)
ive put many o' set of 305/70 on stock 16 wheels with awesome results. speaking from experience. zero issues.
GeorgiaStrokin is offline
The Following User Says Thank You to GeorgiaStrokin For This Useful Post:
marylandstroker (04-02-2014)
post #7 of 8 Old 04-02-2014, 08:26 PM
They are close enough for comparison. 315mm = 12.50 inches. A 315 is also 34.6 inches tall, about what you would expect from a 35.
As far as using a 7 inch rim goes: I wouldn't mount anything bigger than a 255 on a 7 inch wheel. Hell, I really liked my 285s on 10 inch wheels. I run my 315s at no more than 40 psi to not run them bald in the center on 10 inch wheels.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #8 of 8 Old 04-02-2014, 08:44 PM
The red truck is my 315 on a 10" wheel. The goldish truck is a 315 on a stock wheel.
On my truck, you can clearly see that the wheel is much closer to the tread width. The other wheel being so much thinner than the tread width is why the tire looks sucked in so much.
ID:	266825   Click image for larger version
Karls03 is offline
