Fuel hostage wheels Deep lip questions - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
 1Likes
post #1 of 37 Old 03-08-2014, 02:15 AM Thread Starter
ZackMicF's Avatar
Quoted: 32 Post(s)
Talking Fuel hostage wheels Deep lip questions
Im looking at running a new wheels setup on my 01 F250 7.3l
right now im running 35x12.5r20s hancook POSs (i hate them, cant get them balanced to save my life) and they look tiny on my truck
thats because i have a 8" lift now,
im running some Raceline wheels, black 20x10 predators, i like them, theyre okay,
but i really love this deep lip look ive been seeing on some trucks,
i want to get a set of 5 (matching spare) fuel hostage wheels deep lip, im going to be putting them on some Nitto trial grapplers, 38x15.5r20s, should look perfect with the 8" lift,
the question im looking at, is that they come in 20"x12" and 20"x14",
which should i run? the difference in the back spacing is only 1/4"
the price difference is about $30 per rim so $150 total, to go from 12" wide to 14" wide
so does that mean the 14" sticks out 1 3/4 farther to give it a even crazier deep lip look? or would that be too much,
AND would that fit on my truck?
ZackMicF is offline
post #2 of 37 Old 03-10-2014, 08:44 AM
Codyw's Avatar
The backpacking is measured from the center of the wheel. Which size had what spacing? Also I would get the 20x14's. I have 20x12s with 38x15.50 but like the wider look of the x14's
Codyw is offline
post #3 of 37 Old 03-10-2014, 08:58 AM
Codyw's Avatar
Here are pics of mine. These are 12 wide XD armours with MT atz's.
The 14 wides look almost flush with the tires where mine, the tires still balloon out a little wider than the wheelsn
I have 2" spacers also, that's why they stick out of the body so far. I don't know the wheel offset.
ID:	255626   Click image for larger version
ID:	255634   Click image for larger version
Codyw is offline
post #4 of 37 Old 03-10-2014, 09:37 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
20x12 has a -44 offset
20x14 has a -76 offset
that being said, the 20x14 will have much bigger lip because its a wider wheel and also a bigger offset. the 20x14s are prolly what you want, only issue you may run into is rubbing. Im not familiar with that high of a lift and what fits and what doesnt so hopefully someone can chime in with whether or not it will rub
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #5 of 37 Old 03-10-2014, 09:44 AM
Heavy_GD's Avatar
Quoted: 1740 Post(s)
Feedback Score: 3 reviews
based on what you said, you want the 14... yes it is that much wider.
at 8" you might have to space your bumper out for 15.50's, you will clear them fine but they may rub lock to lock
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
post #6 of 37 Old 03-10-2014, 09:56 AM
Quoted: 3 Post(s)
You will need to run spacers to clear your leafs. Contact Cary at CT Performance or Fred Goeske of wheeladapter. 2" wheel centric and hub centric spacers are what you want.
You will also have to trim your bumper (or space it out) and trim the fender liner. I ran 38x15.50 on 20x14's with 9" lift on a 01. I had to do all of this. I had the same issues with 20x12's. It's an easy fix and looks great.
Heavy_GD likes this.
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #7 of 37 Old 03-10-2014, 10:03 AM
Heavy_GD's Avatar
Forgot about the leafs.... Good advice ^^^
GD
...because Patriot.
Heavy_GD is offline
post #8 of 37 Old 03-10-2014, 10:11 AM
travisH3's Avatar
Quoted: 2 Post(s)
so you were running 20x14 wheels and then wheel spacers too????? that whole tire had to be outside the fender
T-rav
2010 F350 6.4-
travisH3 is offline
The Following User Says Thank You to travisH3 For This Useful Post:
bigred3297 (03-10-2014)
post #9 of 37 Old 03-10-2014, 10:36 AM
Hellrazinf350's Avatar
Hello,
It is an awesome setup. Exactly what I am running on my 02 f350. 38x15.50 nitto muds 20x12 -44 fuel hostage wheels. perfect setup with my 8.5' lift. I wouldn't recommend the 20x14 way over kill
2002 F350 CC SB
8.5" PROCOMP LIFT
20x12 -44 Fuel Hostage wheels
38x15.50x20 Nitto mud grapplers
GTP38r turbo/EBV delete
Edge insight CTS monitor
Superchip programmer
Trans rebuild/3 clutch lock up billet tq/JW VB
CCV Upgrade
4"DP..5"Diamond Eye exhaust/muffler delete
BD Uppipes/polished out Y pipe
6637 Air filter
Foil delete
Polished out X pipe/AIH delete
Future Mods: DP Tuner,Stage 2 injectors,08 tailgate,08 diff cover
Hellrazinf350 is offline
post #10 of 37 Old 03-10-2014, 11:01 AM
Codyw's Avatar
20x14 with -76 offset will stick out within 1/4" or so compared to the pic I posted of my 20x12s (with 2" spacers)
Mine was lifted when I got it so I don't know "exactly" how much it is lifted. Compares very close to most other 8" lifts i see though
Here is what CAN happen with the real wide wheels/tires... look at my fenders.
Also your bumper will need to be cut some or moved forward like said above
ID:	255754   Click image for larger version
ID:	255762   Click image for larger version
ID:	255770   Click image for larger version
Codyw is offline
