Need help deciding what size wheels for new tires! - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 1 Old 02-22-2014, 08:52 AM Thread Starter
I'm puchasing some new wheels and tires next week b/c my Duratracs are down to the last bit (only 68,000miles on them) and was going to try out the toyo AT II in the LT295/65/R20 and also get some Fuel wheels in the D260 two piece Mavericks I have attached. With this size tire, it says the wheel size should range from 8-10 on the website and wanted to know what would be the best fit with my lift and these tires. I know they are about a 1/2" narrower than the 12.50 but I'm ok with that and also like the taller look and rating.
What do you guys think would be best the 20x9 or the 20x10. I want the tires to stick out a little bit like my current set does but not have a balloon look with the tires. the store I'm getting them from says to stick with the 20x10's with my lift, but I know my current set up is 17x9, but dont know the offset of my current wheels.
thanks for any input.
ID:	247009   Click image for larger version
ID:	247017   Click image for larger version
Trent
2006 F-250. 5" lift, ICON 2.0 shocks, 315/70/17 Goodyear Duratracs, 17" Weld Wheels, MagHytec cover, 4" Banks Exhaust, AFE Stage 2, Banks High Ram intake, 6000K HID headlights and fog lights, Recon lights,Fumoto Oil Drain , SCT tuned (IDP, Gearhead, Quicktricks), Edge CTS Insight,ARP studs,EGR delete, Powermax turbo w MTW billet wheel, NUC Oil Bypass filter and Dieselsite Coolant Filter,Ford Upgraded Fuel Spring
GAstroker2006 is offline
