Tires for F350 DRW - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
 1Likes
post #1 of 17 Old 02-19-2014, 05:38 PM Thread Starter
Tires for F350 DRW
I'm sure this question has been done to death, but couldn't find an exact answer...I have a 2006 F-350 DRW, Lariat, Crew cab, 6.0, 8 ft bed. I use it as a regular driving vehicle, when needed, and also to haul a 2 horse gooseneck trailer that weighs 4100 lbs empty, but about 5700 lbs normally. Right now there are Transforce tires on there- LT245/75R17. When I look up these tires, it shows they are for light trucks...not sure what they're doing on my truck then, unless I'm missing something.
So my question is, I need new tires and am looking to find out what similar drivers are using and what works best. This is my first truck, I've had it for 2 years, but only the second time it's needed new tires.
Thanks in advance!
Kcscott85 is offline
post #2 of 17 Old 02-19-2014, 06:02 PM
E99F350Stroker's Avatar
I think the tires are supposed to be 235/85/16. My tires right now are some old cooper A/Ts that were on my truck when I bought it. Im getting ready to get a nice set of mud tired but I havent decided which brand yet.
Jordan
*Sold* Early 99 F-350 dually 4x4 6spd 7.3
*Sold 2000 F-250 4x4 ATS auto 7.3
1996 Dodge 2500 4x4 speed, 12 valve cummins, 283000, stock
E99F350Stroker is offline
post #3 of 17 Old 02-19-2014, 06:24 PM
jesilvas's Avatar
Quoted: 3 Post(s)
You ARE a light truck.
Medium Duty -
Heavy Duty -
Do you want highway tires only or all terrain? 2wd or 4wd?
Heavy_GD likes this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 17 Old 02-19-2014, 06:36 PM Thread Starter
Wow, in comparison I can totally see that I am! Thanks for the clarification, I suppose I was thinking "light" as in a Sierra or Tundra, or the like.
I forgot to put in the OP that my truck is 4wd. I have only had to use it twice though in 2 years, since I haul in generally ideal conditions and mostly on highway. I do have to drive on grass/mud occasionally, typically at various horse farms. Not sure if that is enough to warrant all-terrain, but like I said, I am new at this.
post #5 of 17 Old 02-20-2014, 03:47 AM
jesilvas's Avatar
Quoted: 3 Post(s)
I have Hankook highway tires in front (2wd) and their all terrains in back. The all terrains are very stiff, and even at 35PSI, I'm wearing out the middles of the tires first. If I had more weight, they would be wearing perfect.
You need to check the load rating for proper weight capacity.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 17 Old 02-20-2014, 09:43 AM
JER-1's Avatar
Quoted: 17 Post(s)
Use same as mine in sig
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #7 of 17 Old 02-24-2014, 07:57 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
I run Michelin LTX M/S2 LT245/75R17 -Love em-they also have an A/T version of the same tire. The Michelin's also have a 70K tread warranty.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #8 of 17 Old 03-02-2014, 02:42 AM
How do you rotate the tires on a drw? Or do you?
Jlovette is offline
post #9 of 17 Old 03-02-2014, 07:56 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
The only true way to rotate the tires is to have them dismounted and placed on a different wheel there is a specific order here is a link that shows tire rotation.
Rotation - Discount Tire Direct
Shawn
Qholic is offline
post #10 of 17 Old 03-02-2014, 08:55 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Very true.
Since I'm 2wd, I have steer and drive tires for the heck of it.
And I just flip the fronts, and then flip the inner rears with each other and the outer rears with each other. Not perfect, but direction of rotation is changed, so it works.
4R100, 2wd
330,000 + miles
jesilvas is offline
