tire revs? and srl - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 13 Old 02-16-2014, 10:42 AM Thread Starter
tire revs? and srl
hey guys maybe a stupid question but how many revs would 33x12.5x20 tires put out? asking this because I just loaded srl up on the truck and I've seen where some people have said this needs to be delt with. also what about the break in period with the srl? how long?
thanks
zach
Zjbennett94 is offline
post #2 of 13 Old 02-16-2014, 11:37 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
A 33" tire will get you approx. 621 revolutions per mile.
You'll have to match both values in the SCT though, so 620 will do for both.
By both, I mean the REVs in the SCT device AND the SRL tune.
Both are adjustable and folks have problems because they don't adjust both, just one or the other.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #3 of 13 Old 02-16-2014, 12:49 PM
Quoted: 58 Post(s)
thanks
zach
You really should measure them using the chalk procedure. The published revs per mile are accurate for a new and unloaded tire - and don't incorporate tread wear, inflation pressure, and vehicle weight.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 13 Old 02-16-2014, 06:22 PM Thread Starter
I just changed it on the srl tune but can't seem to find how to change it on the sct? truck is a 04 do they have it available for that year ?
post #5 of 13 Old 02-16-2014, 06:36 PM
dfuzz78's Avatar
When you select custom tune from the menu, it will ask you if you want to change the tire revs for speedometer calibration... That's the SCT REV adjustment.
Then you select which tune you want and it will ask you is you want to "adjust user options;" that's the SRL REV adjustment.
The year of the truck doesn't matter.
Also, like someone else talked about the "chalk method..." Rest assured that is the procedure I did to get the REVs of 620.
Good Luck!
Denis "Lt. Sled"
dfuzz78 is offline
post #6 of 13 Old 02-16-2014, 06:52 PM Thread Starter
When I choose custom tunes I am not getting the change tire size option
post #7 of 13 Old 02-16-2014, 07:12 PM
dfuzz78's Avatar
It should say "Recalibrate Speedometer."
Denis "Lt. Sled"
dfuzz78 is offline
post #8 of 13 Old 02-17-2014, 05:06 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
Feedback Score: 3 reviews
Try updating the firmware on the SCT. Make sure you return the truck to stock first then do the firmware update.
When I get new tunes I measure out the tire revs first and ask them to use that measurement.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 13 Old 02-17-2014, 07:10 AM Thread Starter
just updated everything Saturday I believe. maybe I missed the firmware
post #10 of 13 Old 02-17-2014, 03:43 PM
N.S.D.Q.
Quoted: 132 Post(s)
Your SCT software has the function to check the firmware.
