07 F550 has wobble of death in steering between 30-50mph - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 02-16-2014, 04:34 AM Thread Starter
RamAirfreak98ss's Avatar
Quoted: 6 Post(s)
Garage
seems to start when you hit a bump on one side.. the steering wheel starts to jerk left and right violently and only way to stop it is to slow down to about 20mph... its fine for maybe a minute or 20 minutes then does it again.. I'm assuming both front shocks are blown? I saw online the pitman arms don't go bad, i cant find play in anything by manually moving it underneath the truck.
anyone else have this happen? it is an F550 crew cab 201" wheelbase not a F350 dually... so its a little different up front, the shocks arn't the same as what all our other F350s/F250s use, they're larger i guess.
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
post #2 of 3 Old 02-16-2014, 05:19 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
I would bet you have a bad track bar ball joint and track bar bushing. To get the track bar ball joint out you need a ball joint press. I believe you can buy just the bushing for the track bar and replace that. Hope this helps.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is online now
post #3 of 3 Old 02-16-2014, 05:29 AM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
I forgot to mention how to look for the bad parts. First grab a buddy or the wife. Turn the key on with the engine off and have somebody rock the steering wheel back and forth (2"-3" to each side) while you get under the truck and look for any movement in the track bar and track bar ball joint and tie rod ends. If you see any movement the part is bad.
01 f-250, Standard
