tire question - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 23 Old 02-05-2014, 06:28 PM Thread Starter
Powerstroke_21's Avatar
tire question
hey guys, im sure this has been asked a bunch, but I did some searching and couldn't really find what Im looking for, but I may have missed something. If I did just let me know. I have a late 99 f350 ecsb srw that i think has a leveling kit (has 4 leafs in the front) I'm thinking about going with one of these: bfg mud terrain km2, nitto terra grapplers, toyo open country mt, or fuel off road mud gripper. My main question is how big can I go? I have 16" rims. I was going to go with 305/70r16 but was thinking about 315/70 or 315/75 or 305/75. I think I can go with 315 but Im not sure on how wide i can go without rubbing. However I am willing to do a little modification if need be, just don't want to have to do major mods to keep em from rubbing. Im currently running 265/75r16
Also, which are the best? ride wise, traction wise (mud, snow, rain, etc.) wear wise and road noise
thanks in advance for the help
Jarrette
1999 F350 ecsb 4x4 130k miles.
Mbrp 5" exhaust
TS 6 pos chip with Gearhead tunes
Auto Meter CS Series gauges (boost, pyro, trans temp)
S&B Intake
Aftermarket wastegate controller
Mods to come:
Crank case vent
Hutch and harpoon mod (if not already done)
1997 F250 rclb 4x4 gasser
Going to do a 12v swap in it tho
Powerstroke_21 is offline
post #2 of 23 Old 02-06-2014, 07:38 AM Thread Starter
Bump
Sent from AutoGuide.com App
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #3 of 23 Old 02-06-2014, 07:09 PM Thread Starter
Night bump
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #4 of 23 Old 02-08-2014, 12:33 PM Thread Starter
Anybody?
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #5 of 23 Old 02-08-2014, 01:06 PM
Toyo M/T is a hard tire to beat... I neglected mine and they still ran over 40K miles with a bit of life left... I bet I could have made it to 60K with rotations and better alignment!
Pretty quiet on the hwy for a MT tire also...
Good luck on the sizes, if they are going on a 16" factory rim, stay closer to an 11.5 wide tire if you can...
TxOutlaw is offline
post #6 of 23 Old 02-08-2014, 01:17 PM Thread Starter
alright those are what I'm really leaning towards
And yeah they are stock size rims 16 diameter and 8.5 wide. If I go with aftermarket rims what would a good combination in sizes be with what I have? Cuz I have a feeling that I'm not going to be able to find any 11.5 wide tires.
And would it hurt to go with a 12 wide tire, for example 305/70r16?
EDIT: I could go with 295/75r16 they're 11.6 wide and almost 33.5 tall
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #7 of 23 Old 02-08-2014, 03:21 PM
MuddyATV24's Avatar
I had 315/75/16's and they rubbed the leafs at full lock, and would hit the stock bumper if turned and hit a little bump. I dealt with it and they looked good, but when the time came to get new tires, I went with the Toyo AT2 in a 295/75/16. No rubbing, they are much quieter and they still fill the wheel wells nice.
2001 F-350 Lariat CCLB, 7.3L, ZF6-speed, Manual hub conversion
2" Procomp leveling Kit, Stock wheels with 295/75/16 Toyo AT II's
Front and Rear Ranch Hand Bumpers
MuddyATV24 is offline
post #8 of 23 Old 02-08-2014, 03:24 PM Thread Starter
alright cool, are the tires on your truck in the your sig pic the 295/75r16?
Jarrette
Mbrp 5" exhaust
S&B Intake
Mods to come:
Crank case vent
post #9 of 23 Old 02-08-2014, 03:33 PM
MuddyATV24's Avatar
Tires in sig pic are the 315's.
This link should have pictures of the new tires.
Will 295/75/15 fit 02 16" wheels
post #10 of 23 Old 02-08-2014, 03:43 PM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 109 Post(s)
The suggested size is 305/75/Rx (x=random rim size). Though most people put 315's.
I'm putting 315/75/R16 Nitto Trail Grapplers on mine which is also leveled. I do expect rubbing but only at full lock on the leafs which really isn't a big deal and I doubt you'll be able to hear it over your 7.3 anyway. You might also want to trim your bumper a little if you see it rubbing against it.
There really isn't a big difference between A/T and M/T tires except the thread design where one is more meant for off-road use (M/T) compared to the other but doesn't affect road use which is generally why M/T's are more expensive.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
