Skyjacker extended length brake lines - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
 1Likes
  • 1 Post By sabarnes
post #1 of 8 Old 02-03-2014, 06:33 AM Thread Starter
sabarnes's Avatar
I am looking a putting a 2.5 in front -5 in rear Readylift on soon. I have the lift and the instructions require moving the front brake line down on the frame about 2inches. I'm not to keen on rebending the factory hard lines so I am looking at the Skyjacker#825-FBL84 Front Brake Lines 2008-2010 F250/F350 Pickup Super Duty 4WD 4" Lift lines.
The problem is I am reading reviews that state they are not long enough, and don't fit the factory clips. Reviews for the same vehicle describe them as the same length as the stock brake lines. Does anyone have any expirence with them?
All the product descriptions have said the same thing. For 2-4 in lift but nothing on actual length. I have even asked 4wheelparts.com and recieved a canned answer.
They also make Skyjacker #825-FBL86 Front Brake Lines 2008-2010 F250/F350 Pickup Super Duty 4WD 6-8" Lift lines. And again no information on actual length of the brake line.
I would rather spend the extra money for extended length brake lines than risk damaging the hard lines but I need more information before I decide to hit the shop and tear things apart only to find out they ARE the same length.
sabarnes is offline
post #2 of 8 Old 02-05-2014, 06:50 PM Thread Starter
sabarnes's Avatar
Bump. Maybe some input from a vendor?
sabarnes is offline
post #3 of 8 Old 02-05-2014, 11:25 PM
I have used skyjacker, I had a 4" lift made by Skyjacker a while ago. Biggest waste of money I have spent on the Jeep so far
antonyjacaob is offline
post #4 of 8 Old 02-19-2014, 05:04 AM Thread Starter
sabarnes's Avatar
So I finally recieved an iffy answer of the Skyjacker extended length brake lines were 35 in long. Not sure what the actual pproduct looks like.
Because I couldn't get a clear answer and thanks to reviews here on the forum I went with Crown. Really impressed with them. Not only are they very clear that the lines are extended length flexible line not additional hard line. But they showed up with factory style mounting brackets on both the front lines.
Can't wait to get them on to move forward with the lift.
huck2080 likes this.
sabarnes is offline
post #5 of 8 Old 02-19-2014, 05:42 AM
Contact Cary at ct performance. He can get you lined out. He's a forum sponsor too.
Brett
2013 F250 CCLB FX4 4" PURE PERFORMANCE
2013 F150 FX4 LEVELED 285'S
2001 F350 7.3 CCLB ZF6
rustyshakelford is offline
post #6 of 8 Old 02-21-2014, 07:30 PM Thread Starter
sabarnes's Avatar
Just in case any one else is looking at Crown extended length brake lines. This is the kit for a 4 inch extended brake line set 2008 F350 Lariat SRW CCSB 4X4 6.4L.
ID:	246665   Click image for larger version
ID:	246689   Click image for larger version
ID:	246697   Click image for larger version
sabarnes is offline
post #7 of 8 Old 02-22-2014, 01:37 PM
Quoted: 2 Post(s)
There is a video at the bottom of this link that shows how to flip the brake line. I ordered this kit last week. I know your looking for a 2.5 lift and this is a 3.5 lift. Hope this helps out not sure what you bought.
Stage 4 - 3.5" Front / 3.0" Rear 2011-2013 Ford Super Duty SST Lift Kit
2011 F250 6.7 3.55 gears
20" wheels,
Tonneau cover,
Chrome mirror covers and door handles,
Line-X bed liner,
LED grille lights amber,
EZ-down tailgate,
Tinted windows,
3.5"Ready lift kit
Amp steps
Bigtwinharley is offline
post #8 of 8 Old 02-26-2014, 08:31 AM Thread Starter
sabarnes's Avatar
Thanks Ive watched the video. Looks like the 08-10 have a different set up for the brake line than the 11-13. Mine is straight line from metal tube to the mount and joint to the flex line. With the Crown lines I won't have to drill the holes to mount the lines 2" in lower and i don't have to re-bend the metal line to reach the extra two inches. Besides with the price I bought the lift for compared to the listing prices I did well enough to buy the Readylift 69-2516TP and the Crown extended lines for the same price as most are selling just the Readylift. Now to get time in the shop to get everything installed.
sabarnes is offline
