Advice on Snow Tires for 20" wheels - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 23 Old 01-29-2014, 03:58 AM Thread Starter
Q-DawgVFR's Avatar
OK, so there's still lots of winter left up here in the Great White North, and as a new F350 owner, I am contemplating winter tire options. My truck came with the 20" wheels standard on the Platinum package.
First of all, I want SNOW/ICE TIRES, not all-seasons or M&S rated tires, so please no endorsements of non-winter-specific tire models. I live in Canada and we get real winter, and I enjoy the benefits of driving on snow/ice rated radials and the extra safety and protection they offer me and my family.
I've read a lot of tire threads on the forum, and most of them are full of recommendations for various all season or M&S options, which didn't help me too much.
My dilemma is whether to stick with my 20" tire size for winter use, or to get 18" wheels and tires.
A quick search of the 'net turns up very few winter tire choices for the 20" factory tire size, and a few more options on the 18" tires.
My original plan was to keep factory 20" wheels as winter wheels and eventually get some summer aftermarket with a decent mud tread. Now I am actually considering getting rid of the 20"s and getting 18" for winter, but I hate to get rid of such nice factory wheels.
Thoughts from any of the other northerners who have tried some tires and can suggest what to get? I am not brand loyal to any one type of winter tire manufacturer, as I have had good luck with several brands. Just wondering what my options are, because I'm not turning up much in my searches.
Hankook RW11 i-pike was one option for the 20's. Anyone try these?
Q-DawgVFR is offline
post #2 of 23 Old 01-31-2014, 03:43 AM
jetjock15's Avatar
Quoted: 111 Post(s)
I ran cooper discoverer with studs during my time in AK and they work great. Any snow rated tire will do its all the sipping that does it. Studs are a life saving when your dealing with black ice, no tread makes a difference. If you have regular cold winters I'd go the route of different wheels cause you don't want to dismount/mount twice a year.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 23 Old 01-31-2014, 08:18 AM Thread Starter
Q-DawgVFR's Avatar
Thanks. What diameter tire did you run?
Yeah, I'm not fussy on winter tires. Like you say, just having a WINTER tire with the correct compound / siping is what makes all the difference. Sure there are slight differences, but they all pretty much do their job well enough for me.
Biggest decision for me is whether to go with 18" or 20" wheel/tire combo for winter. Ideally, I would pick the stock 20's as my winter wheels, then buy some nice aftermarket 20" or 22" to run in summer. But if ride quality sucks too bad in winter on 20's, maybe I have to consider parting with those nice Platinum wheels for something a little smaller.
One thing is certain, the performance of the 20's with the stock Michelin tires really sucks. They are like rocks, and there is virtually no traction on even the slightest amount of snow / ice. I have driven on worse, but not by much. Trying to navigate icy parking lot yesterday left me swearing as I was crawling around at a walking pace and truck wasn't steering at all as I turned the wheel. I can live with some difficulty in getting going, but I need to steer and stop!
I may wait a year to buy the summer wheels if it requires a little bit of lift to clear 35" tires with my choice. I'm OK with paying for mount / dismount of tires for about a year, but I want 2 sets of wheels ASAP so that I can swap at my leisure. Tire shops get so busy in spring and fall and I don't like the hassle and rolling the dice for possibility of shoddy work.
post #4 of 23 Old 01-31-2014, 08:56 AM
jetjock15's Avatar
Quoted: 111 Post(s)
I ran stock size Coopers on my OEM wheels because I had aftermarket set for summer. After I re-geared my truck i got a used set of Cooper M/T tires that were studded, it was better than nothing. I but the OEM studs on my trailer cause it had the same size wheels when I came down the ALCAN back to states in winter. I remember the dedicated snow tires worked amazing and I ran them on both my 2 door explorer (was my DD) and my wifes newer explorer. All three cars had a winter set of tires/wheels - thats how you have to roll when winter is 8 months long! Good luck, id take whatever was cheapest dedicated snow tire you can find in load range E.
post #5 of 23 Old 01-31-2014, 08:58 AM
jetjock15's Avatar
Quoted: 111 Post(s)
Oh, and from a pure performance on snow/ice standpoint, im sure 20" wheels would be significantly less affective because of the reduced ability for the sidewall to flex. I would want 17" rims and snow tires. Summit sells steel wheels for $80 per free shipping 17x9 4.5 Backspace (thats what my rear snow tires are on in pic!) was $170 to my door.
post #6 of 23 Old 01-31-2014, 09:01 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Goodyear Duratracs are great for ice and snow.
They are "A" rated as a snow tire.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #7 of 23 Old 01-31-2014, 10:26 AM Thread Starter
Q-DawgVFR's Avatar
I guess the only thing that was keeping me from wanting to go smaller is that i already have the 20's, and I was considering keeping brake clearances in case of future upgrades. Plus I have experienced brake/wheel lock caused by snow and ice freezing the wheel solid to the rotor, or rocks jamming between rotor and wheel. I have experienced fewer issues of these types and easier cleaning by running larger wheels.
post #8 of 23 Old 01-31-2014, 01:42 PM
Tattooz's Avatar
Quoted: 2 Post(s)
yokahama Ice guard tires
2004 Excursion
Leveled front, block rear, FUEL OCTANE 20's,Nitto Terra grap's 295/60/20,Tint, Edge CTS, Diamond eye Turbo back stainless 4inch pipe with muffler, 6.0 GONE ~ CUMMINS in !!!!
2011 Crew long bed King ranch 6.7 Mini Maxx,No Limits full Delete, S&B CAI, 6 inch pro comp lift, XD wheels, Toyo R/T
37x13.50x20
Tattooz is offline
post #9 of 23 Old 01-31-2014, 05:57 PM Thread Starter
Q-DawgVFR's Avatar
Found a nice set of 18" firestone winterforce on Mayhem 8050 wheels with TPMS, ready to go for $1600. Very tempted to get them and sell the Platinum wheels to go towards some aftermarket that I like for summer.
What would you do?
post #10 of 23 Old 02-01-2014, 07:19 AM
blue99stroker's Avatar
Quoted: 249 Post(s)
X2 on duratracs they rock in the snow.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
