35 inch tires? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 10 Old 01-28-2014, 08:27 AM Thread Starter
Fire From the Clouds!
Horizon122's Avatar
Quoted: 111 Post(s)
35 inch tires?
It just dawned on me. I want to put Nitto Trail Grapplers LT315/75/R16 on my stock 2002 F350 Lariat rims.
I read that the stock rims are 16x7 and on Nitto's website it says they're 16x8+, will the tires still fit on my stock rims? Iv'e been looking everywhere and can't seem to find 35's in a 16x7 format?
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is online now
post #2 of 10 Old 01-28-2014, 12:49 PM
CSIPSD's Avatar
They will fit fine.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 10 Old 01-28-2014, 12:59 PM Thread Starter
Horizon122's Avatar
Quoted: 111 Post(s)
Originally Posted by CSIPSD View Post
They will fit fine.
Ok thanks. I read that they will fit but will cause uneven thread life, but Idon't really care about that. When is that a big deal?
post #4 of 10 Old 01-30-2014, 10:42 PM
There wont be uneven thread life
antonyjacaob is offline
post #5 of 10 Old 01-31-2014, 03:00 PM
After you pinch those 12.5" tires over that little 7" rim, run some chalk across the tread to get the best tire wear possible. Adjust the air pressure until all the chalk rubs off.
Fact is, the wider the wheel the more psi that you can run to achieve a flat tread contact patch. PERSONALLY, I won't run a 12.5 (315) tire on anything less than a 10" wheel.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 10 Old 03-15-2014, 09:20 PM
Did the tires get installed? How did it work out? Got a picture you could share? I have nine of the stock rims for my '03 and need bigger tires! Just wondering how it all worked out...
Old Ed is offline
post #7 of 10 Old 03-16-2014, 07:39 AM Thread Starter
Horizon122's Avatar
Quoted: 111 Post(s)
No not yet, I was in a accident with the truck while parked and someone side swiped me. So I'm waiting for the insurance check then having a buddy fix everything and with the remaining balance buy all the add-ons I want, fenders, iron cross bumpers, rims, tires, etc. But once it's all done il definitely show pics. Just not sure how long.
post #8 of 10 Old 05-18-2014, 07:29 AM
I'm hoping you got the truck fixed by now! A good friend has a Wrangler DuraTrac, LT 315 /75R16 (new) on yet another matching rim (gives me 10). He is supposed to bring it by any day. That's a 34.6 inch diameter tire on a 7 inch wide rim. Ive got to see it!
Old Ed is offline
post #9 of 10 Old 05-21-2014, 07:16 PM
vegas99's Avatar
what other wheels fit the f350
vegas99 is offline
post #10 of 10 Old 05-24-2014, 06:19 PM Thread Starter
Horizon122's Avatar
Quoted: 111 Post(s)
Believe it or not truck is still in the shop lol (broke life)..... I have been thinking and I might go with PRO-COMP 1069's in 16x10 format as I can get them cheap for about $100/wheel or maybe save up and get XD 797's though the smallest they make them in is 17's. It really depends on how much I save as I plan on getting a matching grille one without the bolt stud look if I get the pro-comp's or one with the studs if I get the XD's.
Any wheel will fit a Superduty 99-04 that is a 16"+ wheel in diameter and has a 8x170 bolt pattern.
BTW sorry for the late reply.
