Brake Calipers - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 01-22-2014, 03:12 AM Thread Starter
Heathrm's Avatar
Brake Calipers
I have researched many threads on brake issues for a while. Some people that have had caliper problems, replace the caliper only to have the same problem within a year or two.
I need to replace the front passenger side caliper, and will replace both the fronts while I do this. My question is which calipers have had better success, Fords, Napa, Oreily's, etc. I usually go with the OEM when replacing parts, should I do the same here with the calipers?
Thanks for any input!
2004 Excursion Limited, 211,000 miles,
Edge CTS (Gauges only), ZooDad, Turbo Timer, DieselSite Coolant Filter,
RCD EGR delete, CCV reroute, Amsoil By-pass Filter, FireStone RideRite Air Springs,
FICM from Ed with Atlas 40 tune, No Kitty, FPR Blue Spring, DC XP270 Alternator
Heathrm is offline
post #2 of 6 Old 01-22-2014, 07:45 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Personally I think you can get away with any of them. Make sure the slide pins are well lubricated and flush your brake fluid. It should really be flushed every 2 years at a minimum.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 6 Old 01-22-2014, 11:06 AM Thread Starter
Heathrm's Avatar
I recently checked and re-lubed all the slide pins, thought that might be the culprit. They are all good, but still have a pulsing from the front. Brake pads are fine, and the front rotors were replaced in June 2013. I think it is just finally time to do the calipers. I will flush the fluid at the same time. Last time that was done is just over 2 years now.
Thanks for the input Mitch.
Heathrm is offline
post #4 of 6 Old 01-23-2014, 08:35 PM
I also changed caliper, i had a problem with my rear strut so I went to a garage, I was told by the mech that my calliper is seized and that my brake shoe was almost worn out (changed 4 months ago with the caliper), and also I can smell the shoe burning sometimes, which was the reason i had changed the calliper.
OEM is good....
antonyjacaob is offline
post #5 of 6 Old 01-23-2014, 10:39 PM
roche837's Avatar
Quoted: 6 Post(s)
Garage
Feedback Score: 4 reviews
In the past 2 years I replaced brakes all the way around, once was advanced auto junk, so then I tried Napa, they failed again but they replaced them for me, just put all new calipers rotors and pads on in August.... we will see.
EMPIRE STATE STROKERS
Studded, 5" exhaust, Sinister EGR DELETE / Coolant Filtration, more to come
roche837 is offline
post #6 of 6 Old 01-25-2014, 06:01 AM
IC31's Avatar
I don't think it makes a bit of difference which brand rebuilt calipers you use. This is an original front part from the now gone '06 F350 and at less then 2 years/38K miles:
It cost me a pair of front rotors as well:
I then replaced these with a pair of NAPA's. Those lasted less then a year before one seized and the other started leaking. The next was a full set of four Centric's along with new Centric rotors from Rock Auto which 3 lasted until last fall when one pin seized even with a good coating of grease due to gouges on the pin. Where did those gouges come from - they sure weren't there when I installed the calipers. Every one of those calipers had lots of good special caliper pin grease on the pins when I installed them. The fix - check them and regrease those pins and the pad slides a couple times a year. My current '11 F250 - it's past due, but at what the current temps are - eventually
Dave W
'11 F250 Lariat CCLB, 6.7, Ford 5th wheel and tow options, Ride-Rite air bags & 1224# Add-a-leaf, plus my summer car, a '31 Ford roadster,5.0/C4/9" and much more
IC31 is offline
