Tire and Lift Help Please! - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 15 Old 01-03-2014, 06:13 AM Thread Starter
I'm doing 20x12 wheels on my 2005 F250. It's stock height now. I do have a 2" level kit for the front. Question is what are good tire options for all year round. I'm in upstate NY. and Also, will 35's on 20's fit stock height on my F250 or do I need a lift or at least the 2" level kit? Thanks for any suggestions!
DirtyDiesel05 is offline
post #2 of 15 Old 01-03-2014, 01:14 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 97 Post(s)
Feedback Score: 3 reviews
Those 20x12 will stick out quite a bit. I'd say you need more lift since they are so wide.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 15 Old 01-03-2014, 01:25 PM Thread Starter
Sorry, there 20x9. I don't know why I put 20x12. Will that be good with a 2" level kit in the front?
post #4 of 15 Old 01-03-2014, 01:26 PM
N.S.D.Q.
Quoted: 97 Post(s)
That sounds much better. OEM wheels run 8" wide. You should be good. I'd look at Toyo AT II's for a great on/off road tire.
post #5 of 15 Old 01-03-2014, 01:27 PM
If you don't intend on lifting it, a 305/50-20 (I think it's a 50) is all that is going to fit. Even on a 10" wheel you are pushing it with just a leveling kit.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 15 Old 01-03-2014, 01:31 PM Thread Starter
I do plan on lifting it just not right away. Wanted to get wheels and tires since my stock ones are shot.
post #7 of 15 Old 01-03-2014, 01:35 PM Thread Starter
Those are decent tires in the snow/slush? We just got hammered with 16" of snow and my stock tires are beat.
post #8 of 15 Old 01-03-2014, 01:37 PM Thread Starter
Those 305/50/20's are pretty much equal to a 33x12 tire if im not mistaken.
post #9 of 15 Old 01-03-2014, 02:10 PM
Correct.
PERSONALLY, I wouldn't run a 12 inch wide tire on anything less than a 10 inch wheel.
Karls03 is offline
post #10 of 15 Old 01-03-2014, 04:30 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Correct.
I running 15.50 on 18X9 wheels and they are flat as glass across the width.
12's are a cake walk.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
