Tire pressure - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 01-02-2014, 03:38 PM Thread Starter
bieryjake's Avatar
Tire pressure
Was just wondering what people were running for tire pressure. I have 285/75r16 and could decide on a pressure.
19 years old and currently going to UNOH for Auto/Diesel Associates Degree
2000 F250 ECLB Lariet
Terminator T500
Farm Boys Diesel 5" Turbo Back Exhaust
bieryjake is offline
post #2 of 4 Old 01-02-2014, 04:35 PM
kingbilly68's Avatar
Quoted: 2 Post(s)
I run 60 up front and 70 in rear. Same size tire. Load range E.
[/SIGPIC]2001 F-250 ecsb 4wd auto 150,xxx miles. 6637 factory straight pipe. Amsoil bypass system. Triple Gauge Pod.
kingbilly68 is offline
post #3 of 4 Old 01-03-2014, 04:49 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Tire pressure is going to really affect the ride characteristics. I would take a look at stated pressure on tire at max load and drop it 10 psi and see how it does. Best way to monitor inflation is by watching the pressure when tires are hot.
Typical tire pressure climbs 6-7 psi when hot. This goes up with tire size to a degree. If they are under inflated they will be higher then a additional 6-7 hot.
Fuel milage will also drop if pressure lowered too much.
This is my recommendation: get the air out of tires and fill them with nitrogen. Much more stable don't expand with heat so pressures stay the same hot or cold within 1-2 psi.
Nitrogen is a larger molecule than air so a lower pressure is needed to give same load rating. It also does not hold moisture like air do tires and rims do not degrade with it's use.
Probably more info in a direction you weren't thinking about. lol
But it's great stuff, I have it in my tires and will not go back to air period.
Try some different pressures and see how you like the handling.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 4 Old 01-05-2014, 12:07 AM
Wheel width plays a HUGE part in tire pressure. When I had 285s on an 8 inch rim, 45~50 psi made the centers wear out first. But, that same brand 285 on a 10 inch wheel had even tread wear at the same 45~50 psi.
With a NEW tire, run chalk across the tread and drive around the block, adjust tire pressure until the there is little to no chalk left on the tread. This is pointless on a tire that has uneven tread wear across its width.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
