Question between 18 and 20 inch rims - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 1 Old 12-27-2013, 06:45 AM Thread Starter
COONASS
WHAT HAPPENED's Avatar
Right now I have 35 R16's BFG....
So im looking at changing the rims and tires on my truck...
Tires and rims that i want...
Toyo ATII 35x12.50R18 with an 18x9 inch rim
or
Toyo ATII 35x12.50R20 with an 20x10 inch rim
I did the "math" and the difference in rubber between the two rims is 1 inch...
Question's
1. Will there be a "ride quality difference" with 1 inch difference of rubber between the two rims?
2. Will I have any clearance issues with the 20 or 18 inch rims (different back spacing)?
3. Any other things that i need to know going from 18 or 20 besides the $$$ difference?
Suspension
Going to upgrade to 3.0 King Coil overs with about 4.5 inch lift in the front later on (right now it has a level spacer lift in the front).
2005 CCLB FX4
ARP, EGR Delete, 5 inch TB, SCT Livewire, Sinister Coolant filtration, ECL-1, PHP TUNES
Federal Ownership Respectfully Declined
WHAT HAPPENED is offline
