Abnormal wear on Toyo MT? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 12-25-2013, 06:47 AM Thread Starter
Just took a look at my right front tire and saw this. Is this normal wear for these? I just had the truck aligned a week ago so an alignment was performed by a professional and they even gave me a print out of the results. Tires have 4k miles in them and just started to notice this.
[IMG][/IMG]
[IMG][/IMG]
2005 F250 - Coolant filter, Banks intake, Zoodad, Atlas 40, Edge Evolution, 18" Gear Alloy Big Blocks wrapped in 33 Toyo MT's, MBRP Straight Pipe, EGR delete
mcflyin is offline
post #2 of 5 Old 12-25-2013, 05:09 PM
fordtrix's Avatar
What is the issue you're seeing?
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #3 of 5 Old 12-25-2013, 05:23 PM Thread Starter
I see all of the front edges being work down. That is what concerns me.
mcflyin is offline
post #4 of 5 Old 12-28-2013, 04:17 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 555 Post(s)
Garage
Just keep a eye on the small split line in the treads. If they start wearing at different rates you have a issue. But the sharp edges are going to wear back. I have the same tires and I have closely watched mine too. I have 34,000 miles on 38/15.50/18's and they will go at least 20,000 more. Keep eye on inflation go make sure entire surface hits ground can use chalk and even water to see contact area. Don't overinflate.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 5 Old 12-28-2013, 05:40 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
what are you driving in mostly. highway, dirty roads...etc
Big_Smokey is offline
