Kumho Road Venture MT vs Toyo Open Country MT - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 24 Old 12-17-2013, 03:40 PM Thread Starter
mad103's Avatar
I've done a search on the forum and on Google and I just run in to old threads. I'd like to get updated opinions on which tire is better because I need to replace my 38s soon. I currently am running the Toyos 38x15.50r20 and got a little under 30k miles out of them. They are 8 years old with some tread left but horribly dry rotted. I am disappointed in the way they dry rotted and I do not want the same to happen again so I don't know if I should just go with Toyo's again or save good $ and go with Kumho Road Venture MT. I don't drive my truck too much (30k short distance miles in 8 years) all on road but do drive it in snow yearly
I also read Toyos are a 10 ply and Kumhos are 8 but I looked them both up and they both show 8 in the 38x15.50r20.
Any opinions please as I need to buy soon.
Thanks
2005 Ford F-250 Black/Brown Lariat 4-door/shortbed
8" Fabtech Lift
20" Rims and 38" Tires
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #2 of 24 Old 12-18-2013, 09:00 AM Thread Starter
mad103's Avatar
Anyone?
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #3 of 24 Old 12-18-2013, 09:16 AM
fordtrix's Avatar
I'm not sure what average tire life is in regards to years, but 8 years for a set of tires sounds pretty good in my opinion, even without miles. Especially if the vehicle was stored outside in the sun.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #4 of 24 Old 12-18-2013, 09:22 AM
6.0 stroke's Avatar
Ive had the toyos and the kumho mt, for me both sets wore about the same the kumho's might have lasted a bit longer. there both quiet and smooth on the highway, down fall for the kumhos is that they are directional..
For the price difference I would buy the kumhos again over the toyo mt just my .02
2006 F350 Lariat cc sb
ARP head studs 245ft-lb, ford head gaskets
RCD 175cc 30%
blue spring
egr delete
4" exhaust
sct livewire
srlXX
coolingmist water methanol 10 gph nozzle
afe intake
intake horn
6" skyjacker 20xd hoss 37 toyo mt
stock trans
6.0 stroke is offline
post #5 of 24 Old 12-18-2013, 09:54 AM
Mo Diesel sir!
sleepy steve's Avatar
Quoted: 51 Post(s)
ive run both before and the toyos were loud in my opinion...the kumhos lasted me about 30-35k miles. not sure how long the toyos last because i sold them and got some pro comp extreme ATs it all depends on your driving style and how often you drive in the mud but i think an aggressive AT tire would work just as well as MT and last longer. just my opinion but hope it helps
2003 F350 6.0 CCSB 4x4
3.5" lift with 17" MT Classic II 35x12.50/17Terra Grappler G2
4" MBRP turbo back cat delete, ARP studs,
SCT Tunes from PHP & WPE, Bullet Proof EGR cooler,
HID heads and fogs, 08+ tailgate/tails/mirrors,
LED bars and pods, FICM from Ed, Blue Spring
DC Power 270 alternator, Mishimoto intake elbow,
Mishimoto Coolant Filter, Scan Gauge II,
A-pillar gauges (Boost, EGT, Fuel pres.),
Air Compressor for Sh**s and giggles
for life!
sleepy steve is offline
post #6 of 24 Old 12-18-2013, 11:15 AM Thread Starter
mad103's Avatar
Thanks for the reply guys.
Which of the two are wider? I am going with a 38x15.5x20 but heard Kumhos do not run true to size. Are they taller, wider, etc... than Toyos?
I was considering an AT since I do not mud much, only a few times, but do drive up in the snow in Tahoe and would like to do some trail rides next year. Any recommendations on ATs in my size? How are they on price?
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #7 of 24 Old 12-18-2013, 03:18 PM Thread Starter
mad103's Avatar
I've also read that kumhos are lower tier tire and that Toyo is a premium tire. I just don't know if the premium is worth an extra $500...
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
post #8 of 24 Old 12-18-2013, 07:03 PM
Mo Diesel sir!
Quoted: 51 Post(s)
i ran my kumhos in tahoe and they worked fine...most trail rides dont need a mud tire unless you plan on doing your trails right after a rain storm or when it is raining or snowing...i run yokohama geolander ATs on my 2wd ranger and ive been in snow with those before with no problems. look at tirebuyer.com or tirerack.com or even discounttiresdirect.com those are the sites i use when i need to price tires. i also have a guy at a local shop here that i try to get the price down even more. where are you located since u go to tahoe?
for life!
post #9 of 24 Old 12-18-2013, 08:01 PM
JD_MILLS's Avatar
I've ran both. My biggest problem with the toyo's where they couldn't be balanced. I had multiple places try. Finally decided I would have them trued then balanced. Got to the place that does it. They check them and I was told unless I wanted a slick tire it wouldn't be a good idea. So I replaced them with a set of kumho road venture took it back to the same place to have them balanced now I have 3 tires with no weight at all. And 1 with 2oz of weight they are a much better tire than toyo. I will never make the mistake of buying toyo's again. They may make a decent tire in the smaller sizes. But definitely can't in the larger ones.
2008 f-250 LARIAT, SCT LIVEWIRE, S&B CAI, 8" MBRP STACK
JD_MILLS is offline
post #10 of 24 Old 12-18-2013, 08:49 PM Thread Starter
mad103's Avatar
I am in Northern California and travel a lot to Tahoe during the winter. I've actually slid/slipped twice with my toyos and wonder how kumho would do
What size tire do you run? Besides balancing issues what else can you say about the road performance in dry and wet weather, treadwear and off-road of the two?
8" Fabtech Lift
LineX Bedliner
MBRP Straight Pipe
AirRaid CAI
mad103 is offline
