Military tires - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 11 Old 12-16-2013, 11:48 AM Thread Starter
stroken828's Avatar
Military tires
Is anyone out there running military tires 44" or larger? in the near future im going to need a set of goodyear 46" MVT. need to know who has them. suggestions needed!
thanks guys.
stroken828 is offline
post #2 of 11 Old 12-16-2013, 01:30 PM
They are heavy real heavy.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #3 of 11 Old 12-16-2013, 01:58 PM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
Are you buying used?
If cost isnt an issue look into the conti MPTs, after only 1000 miles I am in love with mine.
I know a distributor here if you are interested.
GD
Heavy_GD is offline
post #4 of 11 Old 12-17-2013, 02:01 PM
WVRidgeRunner's Avatar
395/85R20 46" tall Goodyear MVT
Haven't dealt with them but prices seem decent. They're used but most of the tires we change on our equipment there's little or nothing wrong with and would last a LONG time on a regular pick up.
1999.5 707 Conversions Super Duty 7.3 Crew Cab LB Dually 4x4 Edge Evolution, Oil HPx, Fuel FRx, tons of filters, hutched n harpooned, B&W turnover ball and 5th wheel, lotsa goodies.
WVRidgeRunner is offline
post #5 of 11 Old 12-17-2013, 06:47 PM
You got any links to tires?
ramz trk is offline
post #6 of 11 Old 12-17-2013, 09:44 PM
Heavy_GD's Avatar
This is the Conti site
http://www.continental-specialty-tir.../mpt81_en.html
I went to local distributor who shipped them to me from conti
GD
Heavy_GD is offline
post #7 of 11 Old 01-22-2014, 11:47 AM Thread Starter
stroken828's Avatar
thanks for all the replies guys. i have a set of 46 in good years mounted on 20 in rock stars and they only read 20 psi when fully aired up. anyone every have this problem?
post #8 of 11 Old 01-24-2014, 05:36 AM
Quoted: 3 Post(s)
How do you know they're fully aired up if they're only reading 20psi?
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #9 of 11 Old 01-24-2014, 06:35 AM Thread Starter
stroken828's Avatar
well i dont know if they are fully aired up but they sure do look fully aired up and they are hard as rocks. which leads me to believe they are pretty full. and i dont want to put too much air in.
post #10 of 11 Old 01-24-2014, 07:34 PM
Quoted: 3 Post(s)
Even with zero air in those tires, they'll still be hard as rock. Do a chalk test. Mark a line of chalk across the tire and drive around the block. If all the chalk is gone its underinflated, if only the chalk in the middle is gone its overinflated. Another way to tell if its underinflated is heat.... the tires will get really hot when aired down.
Now, these tests are for conventional tires. Military tires can run in any condition. They won't make your gauge read wrong though. ..
01 Ex 7.3l Limited
06 headlights
