Spongy pedal problem - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 12-12-2013, 07:13 AM Thread Starter
Hey guys so last night i was checking my rear brakes that were acting up and found that the brake material on one of the shoes was falling off of the metal. So i decided to change out the brakes. After about 3 hours of fighting the springs i finally got the new ones on. When i went out to test them the brake pedal is very spongy at first but stiffens up at farther down. I first assumed they needed bled but the e-brake pedal also now goes to the floor. Do they just need adjusted out more? Or is it possible air got into the system? I did not replace the wheel cylinder, just the shoes so idk how air could've got in. Thanks! Oh and it is a 1997 f-250 7.3l 238,000 miles.
powerstroke814 is offline
post #2 of 3 Old 12-13-2013, 08:16 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 581 Post(s)
Garage
Did you make certain the front shoes were in the front and rears in the rear. Also were the adjusters tightened up.
I am not familiar with these trucks but I am guessing they are not much different then older trucks.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 3 Old 12-19-2013, 05:38 PM
keep's Avatar
Garage
You need to adjust the star tensioner. Once you do that the parking brake will take up again and you will have a solid pedal higher up. The better the Jo. You do, the higher up the pedal will get hard.
keep is offline
