Oversize tire question - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 12-07-2013, 09:14 AM Thread Starter
jcmoyer2004's Avatar
I have a 1995 f-250 with the stock alcoa aluminum wheels on it. I'm wanting to run some larger tires on the rear (like 33x12.5) on the rear but i'm wondering what is the largest/widest tires i can run on the stock wheels. Mine is a 2wd and i like the look of a taller/wider mud tire on the rear since i'm in pastures from time to time. thanks guys.
08 F350 Regular cab 4x4 dually 6 speed...mods are on their way
jcmoyer2004 is offline
post #2 of 3 Old 12-08-2013, 09:25 AM
Quoted: 392 Post(s)
I wouldn't mix tire sizes between fronts and rears. Trucks aren't designed to have different sizes of wheels between front and rear and even a small difference can have a dramatic effect of vehicle control and stability.
2005 F-350 ext. cab long box, FX4
EDGE Insite CTS w/ fuel pres, EGT, and rear diff temp
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella ELC
Rotella T6 5w-40 Synthetic
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
268 000km/167 500 miles as of Jan. 1 2015.
Canadian Mind is offline
post #3 of 3 Old 12-09-2013, 02:32 AM Thread Starter
Thanks for the input Canadian, but i have run a larger tire in the rear of my 2wd 3/4 ton for years and have never had any issues out of them. I'm just trying to find out what size i can run on this stock wheel.
