Wheel Offset - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 11-24-2013, 05:08 PM Thread Starter
RY86's Avatar
Wheel Offset
Hello,
I just had a small question that I hope someone could help me with. I am going to install an ICON 4.5" lift on my 2006 F250. An I really like the look of Fuel Offroad Throttle rims. Do I have to run a curtain offset on an aftermarket rim? Do you think a 20X10 wheel will hang really far out of the wheel well. Any insight would be most helpful.
Thanks
Ryan
2006 Powerstroke 6.0
Blue spring mod
CAT EC-1
Coolant filter
Garrett Powermax turbo
Tuned by gearhead performance
MBRP 4" tubro back exhaust 5" rolled tip
4" ICON suspension lift
35" toyo MT's
BMF Novakanes
RY86 is offline
post #2 of 3 Old 11-25-2013, 04:20 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 445 Post(s)
Garage
I forget the offset on my wheels now but I went with 18x9 pro comps with 5.5 backspace I think????
Anyway they were the tightest I could find to keep under the fenders. I had some 20x10 wheels that hung out like crazy when I bought truck. First thing I got rid of.
My wheels are maybe 3" deep on the outside it's all inside.
Just be careful how much backspace you get do some research.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 3 Old 11-27-2013, 07:33 AM
wired1's Avatar
As long as you stay with a 35" tire you will be fine with those wheels. They make those wheels in a -12 and a -25 offset the -12 would be your best bet as thats a 5" backspace and will work real good on your truck. I run a 20x10 -24 offset with a 37x13.50 and they stick out 4" to out side of tire/ fender. But with a 35"x12.50 and the 20x10 -12 wheel you should be right around 3" sticking out. I can get pics of my set up if you want just for an idea.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
