Tire/rim question - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 11-16-2013, 05:50 PM Thread Starter
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Tire/rim question
Ok so I am getting ready to buy new tires.I have 17x6.5 alcoas wheels. I want to run 265/70/17 tires(for better looks),but the recommended rim size is 17x7,so is it a bad thing to run a slightly smaller(1/2 inch) rim ? I use my truck for pulling 13-14k fifth.Please give me your thoughts. Thanks
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #2 of 3 Old 11-17-2013, 08:59 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 463 Post(s)
Garage
You will be fine. I am under 2" on mine and they still have a flat footprint.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 3 Old 11-17-2013, 05:45 PM
On my 99, I run 285/75's on stock Alcoas in the winter. They have a bit of sidewall bulge, but the tread sits flat and they wear evenly.
If you have a dually, make sure there is proper clearance between the sidewalls.
2013 F-350 Platinum 6.7 4X4 CC LB
2007 F-150 XLT 5.4 4X4 SC SB
1999 F-250 XLT V-10 4X4 CC LB
XR250R is offline
