Will these tires fit my truck? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 11-09-2013, 09:56 AM Thread Starter
Fire From the Clouds!
Horizon122's Avatar
Quoted: 110 Post(s)
I'm in desperate need of new tires and want the Nitto Trail Grapplers. My Rims are 16's but the problem is Nitto only makes 3 sizes for that rim.
265LT, 285LT and 315LT.
My current tire size is 265 and they look so small and I hate it plus I have a lot of room left in the wheel well. I'm running a stock height with a lifted rear suspension.
I want the biggest size which is 315's but will they fit? I also plan on putting a 2.5inch leveling kit in the front and it said the suggested size is 305's so can I make the 315's work with no problems?
The 285LT also comes in 2 different sizes.
285LT 122P-31.88" overall dia.
285LT 123Q- 33.03" overall dia.
315LT 124Q- 34.80" overall dia.
So which should I go with that will give me the biggest fit possible as I prefer the stuffed look. My truck is also a 02 F350 Lariat as in my sig.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
post #2 of 5 Old 11-09-2013, 10:02 AM
ngaraiderman's Avatar
I think the 315's will fit.
ngaraiderman is offline
post #3 of 5 Old 11-09-2013, 10:06 AM Thread Starter
Horizon122's Avatar
Quoted: 110 Post(s)
Will they rub? Does it matter if they do as will it cause damage to the truck or anything? The 315's offer the highest load cap which is a must for me so it would be a little disapointing if I can't get them.
post #4 of 5 Old 11-09-2013, 04:32 PM
BIG Laing's Avatar
Just FYI, 285, 305, ect.... are widths of tires in MM. 122p, 123q, 124q are load ratings, and have nothing to do with the diameter of the tire.
A 295/70r18 is taller and skinnier then 305/60r18. The middle # (70,60, ect...) is the aspect ratio of sidewall height to width.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 5 Old 11-09-2013, 05:12 PM Thread Starter
Horizon122's Avatar
Quoted: 110 Post(s)
Well thanks for the info. I'm kinda a noob in some areas and I recently got my dads truck and want to make it a off-road beast.
Here is Nitto's site. Do you mind telling me which 16" Rim tire is the best for a stock height with a lifted rear and with a 2.5" leveling kit in the front. I want the biggest in height possible as I like the stuffed look.
Trail Grappler - Trail Terrain Light Truck Radial
