will Toyo Open country A/T II 295/60R20's rub on my 05??? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 10 Old 11-05-2013, 04:09 PM Thread Starter
Quoted: 10 Post(s)
Im not planning on lifting my truck. I just want to keep the same overall tire just a little wider. I was going to put these on with RPB wheels 20 x 9.5 wheels. Anyone know the proper offset as well?
I have an 05 4x4
2005 Dark Blue F-250 Harley Davidson 4x4. SCT Livewire TS, 4" Silverline TBE, Sinister intake elbow, Riff Raff turbo boots, Blue spring, 6.4 banjo bolts, Sinister coolant filter, Fleetguard OAT, IPR EGR delete, ARP studs.
1998 Dodge Viper GTS. Silver/Blue stripes 1 of 21: Corsa exhaust, high flow cats, K&N filters, smooth tubes
Invasivore is offline
post #2 of 10 Old 11-05-2013, 04:27 PM
mtpolarbear's Avatar
Keep your stock size. You will lose mileage with bigger tires. I lost 8mpg. Going back to stock next week. Just my $.02
POLARBEAR - 2003 F-250 SD CC SB FX4, 6.0, 3:73 gears, EGR & Cooler Delete, Bulletproof Oil Cooler, ARP Studs, A.R.E. Topper, Bedrug, Zoodad, 5" Magnaflow turbo back, K & N cold air intake, coolant filter, EDGE INSIGHT CTS, SCT X3 Tuned by Vivian, Energy Suspension Master Bushing kit, RiffRaff Boots, Blue Spring, 6.4 Banjo's, Fumoto Oil Valve, Fumoto water drain plug, Whistler 2000 Watt Inverter, DC Power 200amp Alt. Rebuilt FICM w/Atlas 40, Riff Raff Boots and counting.
mtpolarbear is offline
post #3 of 10 Old 11-05-2013, 04:35 PM Thread Starter
Quoted: 10 Post(s)
You lost 8 mpg by going to an inch wider tire? Lol
post #4 of 10 Old 11-05-2013, 04:43 PM
Sad but true.
post #5 of 10 Old 11-06-2013, 01:19 AM
BIG Laing's Avatar
Sad but true.
Haha ^^^ no way in hell you lost 8 mpg.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #6 of 10 Old 11-06-2013, 02:06 AM
Snake's Avatar
Quoted: 47 Post(s)
Not even close to answering his question. And not even close to an accurate situation. Don't be too bummed if you only gain 2-3 mpg after returning to stock.
Back on topic.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #7 of 10 Old 11-06-2013, 04:14 AM
ngaraiderman's Avatar
for the 2nd time ever i agree with BIGLAING!!!
ngaraiderman is offline
post #8 of 10 Old 11-06-2013, 04:12 PM
Koda22's Avatar
Quoted: 5 Post(s)
Yea I went to 35s and didn't even see that much of a drop....they should fit, most can fit a 35 with little to no rubbing...but as far as offset goes, got no real clue...but I know backspacing for 05-07 is around 5inches.....
Koda22 is offline
post #9 of 10 Old 11-06-2013, 05:40 PM Thread Starter
Quoted: 10 Post(s)
I also need a suggestion for wheels. I don't want all black wheels. I like the rbp 96r capped wheels. Anyone else have a suggestion?
post #10 of 10 Old 11-10-2013, 07:58 PM
I have 2.5 level 35x12.50r20 toyo open country m/t on factory 20s and don't rub so I am fairly certain you shouldnt run into problems ,btw i lost about .2 -.3 mpg on mud tires
2005 F-250 Lariat FX4 White/Tan CCSB, EGR Delete, 5 inch MBRP straight pipe with 6x18 RBP tip 2.5" level, Factory 20s, 35" Toyo M/T, ptm door handles, KR bed/bumper trim, Recon smoked mirror lights, Line-X, TSC black low-pro toolbox.
PowerstrokeFX4 is offline
