Will these work? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 10-27-2013, 08:36 PM Thread Starter
mr.limited04's Avatar
Will these work?
I have a 2000 f 250 and Im looking at a new set of wheels. Will these fit 22x9.5 with +10 offset I am going to add a leveling kit as well
2000 F 250 7.3
2004 F 350 6,0(sold)
mr.limited04 is offline
post #2 of 4 Old 10-28-2013, 01:00 AM
BIG Laing's Avatar
You need a negative offset for 99-04 SD's. So no, they will not work.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 4 Old 10-28-2013, 06:19 AM Thread Starter
Ok thanks any suggestion on the offset
2000 F 250 7.3
post #4 of 4 Old 10-28-2013, 12:34 PM
BIG Laing's Avatar
Depends on the width of the wheel, and how far you like them sticking out. -12 on a 9" wheel would be as close to stock without rubbing the leafs. You could easily run a -24 too (1/2" further out then -12). I'm not a fan of the real wide so called "bulldog stance" that you will get with some extreme offsets such as -40 or so.
