2005 f350 off set help on 20x10 wheel - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 10-23-2013, 06:10 PM Thread Starter
I have a 2005 f350 with 6" lift I want to go 37x12.50x20 with a 20x10 wheel .I want the tire to exceed the fender some . What should I go with for off set 24 ?
Thank you for your help.
s10pro is offline
post #2 of 3 Old 10-28-2013, 04:39 PM
heisman01's Avatar
Quoted: 52 Post(s)
-24 will give you a good stance since the 05+ axles are wider. I have a -44 on mine but the more narrow axles, just depends how wide you want it to be.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #3 of 3 Old 10-28-2013, 04:54 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Here are a few pics of mine with 18x10's with -24mm offset, the tires stick out about 2" past the fender edge:
I have added fender flares to my truck now:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
