need help 05 f350 6'' ruff country lift, what rim and tire combo? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 10-20-2013, 04:42 PM Thread Starter
2005 f350 with 6"ruff country lift rad arm drop kit. What rim and tire combo and what backspace want them to exceed the fenders a little ? I was thinking 37x12.5x20 4.5 backspace thoughts please? Also what radial do people recommend for a 37 in a radial
s10pro is offline
post #2 of 3 Old 10-20-2013, 07:37 PM
I run a 35x12.5x18 5" backspace on my 4.5" Rough Country lift. You'll probably end up with about 1.5" of tire poking out the fenders if you have stock flares. Also, if you go 37" I'm pretty sure you want 37x13.5. As far as a tire goes there's tons of options, depends on what you're using the truck for.
The_Auto_Tech is offline
post #3 of 3 Old 10-21-2013, 12:33 PM
Gburow's Avatar
If you want a 37x12.5 go with the nitto trails if you want a 13.50 go with toyo
Sent from AutoGuide.com App
Gburow is offline
