any benefits to bigger rims.....? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 10 Old 10-18-2013, 01:34 PM Thread Starter
I currently have the factory 16" rims on my 2004 F-350 with 295/75R16 tires on it. I am wanting to either paint my rims black or buy black rims. If I buy rims is there any benefits or advantages to getting bigger rims like 20" rims. I dont really want to get tires that are much bigger then what I got, but it seems like most of the black rims I can find are 20" rims, I have found a few other sizes, but I wasnt sure if there is any benefits or advantages to bigger rims. If you could let me know I would appreciate it. Thanks,
Will
2004 F-350 Lariat Crew Cab FX4, Dark Grey, T3 Front and Rear replacement bumpers, Fumoto valve, Diamond plate running boards, Zoodad mod, Dieselsite coolant filter w/ ELC, Blue Spring Mod, LED cab lights, Edge Insight CS, SCT SF3, PHP FICM/ECM rollback, Sinister EGR Delete, 6.4 Banjo Bolts, ARP head Studs, Zone Offroad Leveling Kit, CCV Mod, Straight Exhaust, S&B intake, Atlas 40, 295/75R16 BFG,
fishmanwill is offline
post #2 of 10 Old 10-18-2013, 02:06 PM
BIG Laing's Avatar
No benefits, just looks. The reason wheels have been getting bigger over the years on our trucks, is to accommodate bigger brake rotors.
Eventually 18" tires wheel be the cheapest tires to buy IMO, as they are more popular then the 16's and 17's these days. Heck maybe in 50 years 20" tires will be the cheapest.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 10 Old 10-18-2013, 02:45 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
There are a lot of black wheels in 18s and 17s. Its personal taste i think. i like the 18-20 inch wheel range.
Big_Smokey is offline
post #4 of 10 Old 10-19-2013, 03:19 AM
I have had a lot of different sized rims from 15-24. What I have found is the less side wall you have the less side roll you get going through turns. It's a leverage game, the shorter the side wall the harder it is to bend.
Wideright is offline
post #5 of 10 Old 10-19-2013, 07:16 AM
Term3's Avatar
Less sidewall also means a harsher ride and a rim that is more easily damaged by something like potholes.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 10 Old 10-20-2013, 03:16 PM
heisman01's Avatar
Quoted: 52 Post(s)
You can also upgrade to the 05-07 style rotors and calipers which are bigger and need an 18" or larger wheel.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #7 of 10 Old 10-20-2013, 03:27 PM
BIG Laing's Avatar
05-14 needs a 17" wheel or bigger.
post #8 of 10 Old 10-20-2013, 03:31 PM
Diesel Addict's Avatar
Actually the 05-07 truck brakes fit inside 17 inch wheels. They came standard with 17's and thats whats on mine. However I agree a slightly larger wheel looks better,especially on large trucks like ours. Thinking about upgrading to 18's when I need new tires.
2006 F-350 CCLB
6-Speed Manual
6" Fabtech Lift, looking to go a few inches shorter and higher quality
35" Toyo Open Country MT's
AFE stage 2
MBRP 4" turbo back straight pipe
SCT Livewire tunes by Eric
Studded and deleted
The right to keep and bear arms SHALL NOT BE INFRINGED!
Diesel Addict is offline
post #9 of 10 Old 10-20-2013, 07:39 PM
While I will say that the 20's do look nice I feel an 18" wheel looks very at home on the 99-07. The 08-up seem like they need a 20" wheel to really look right.
The_Auto_Tech is offline
post #10 of 10 Old 10-20-2013, 08:56 PM
One advantage to bigger rims would be resale if you wanted something else later on.
Rims that fit all year trucks would have more potential buyers.
I'm selling some 16's off my 99 and it's a bit harder since they only fit up to 04.
2013 F-350 Platinum 6.7 4X4 CC LB
2007 F-150 XLT 5.4 4X4 SC SB
1999 F-250 XLT V-10 4X4 CC LB
XR250R is offline
