8" Lift Tire Size Help-- 2006 6.0 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 15 Old 10-17-2013, 07:13 AM Thread Starter
My last F250 (8" Fabtech lift, 20x12 Fuel Hostage Deep -44 offset, with 37x13.50 Open Country MTs) was stolen a few months back. Finally got everything settled with the insurance company and bought another 2006 this past weekend. I am ready to order parts for it and have a quick question.
I am going to the 8" BDS 4-link system this time and will be running the exact same wheels but in black (20x12 Hostage Deep -44 offset). I am struggling to find 37s in a decent price but found a complete package on Ebay with 38x13.50. I previously had to trim about an inch of the front inner wheel well to accommodate the 37x13.50 on my old truck. The only time I would hear anything was at full turn but it annoyed me enough to trim that back part of the lining a bit. Think I will have to cut out even more with the 38x13.50? If so, I may just wait until Toyo produces more tires and fills in back stock at some of these places with long wait times.
4x4Rookie is offline
post #2 of 15 Old 10-17-2013, 08:35 AM
Quoted: 3 Post(s)
You had 37x13.50 and had to trim. Now you're going to 38x13.50 and you want to know if you'll have to trim more?
Yes
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #3 of 15 Old 10-17-2013, 08:38 AM
7.3pwrstrke's Avatar
The specifications on Toyo's site says...
So the 38x13.50 is .7" taller and .3" wider. I really don't think that's a big enough difference for it be noticeable.
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #4 of 15 Old 10-17-2013, 10:05 AM
Quoted: 3 Post(s)
Also, Air pressure makes a big difference in this equation. If you're running full PSI and are unloaded, you can definitely air them down some. That'll help with clearance
01 Ex 7.3l Limited
06 headlights
post #5 of 15 Old 10-17-2013, 10:08 AM Thread Starter
I wasn't expecting not to have to trim at all...I was just curious if I am going to have to get crazy with the Dremel. I just want to make sure I wasn't taking something into consideration where 1" in extra tire leads to 5" more of cutting.
post #6 of 15 Old 10-17-2013, 11:13 AM
You could always get a small wheel spacer. I saw a bunch of 1/4" & 1/2" wheel spacers on ebay, just search "8x170 1/4"
post #7 of 15 Old 10-17-2013, 11:36 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
Stay away from the wheel spacers unless you buy the best of the best which get very expensive dont buy that cheap stuff off of ebay.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #8 of 15 Old 10-17-2013, 01:32 PM
WideFord's Avatar
i run 38x15.50x18s and it dont rub anywhere. but then again i have custom front fenders.
WideFord is offline
post #9 of 15 Old 10-17-2013, 04:12 PM
Who makes you fenders?
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #10 of 15 Old 10-17-2013, 04:20 PM
WideFord's Avatar
I have the Hannemann fiberglass kit.
WideFord is offline
