01 f 350 going from stock to 18" - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 2 Old 10-10-2013, 05:24 PM Thread Starter
Looking at putting a set of eagle 197's with 305 65 18 bfg KO's on in place of the 285 75 16's on stock rims. I think that should keep my circumfrence close. Anyone know anything about the eagle rims are they any good. I do some heavy towing with the truck and dont want any problems. Do yo have to run a centering bushing with most aftermarket rims and does that cause problems? I have a 2" leveling kit on now. Want to keep the tires under the fenders should I keep a 4.5" backspace. Just looking for a little advice if anyone has a similar setup or pics of the 197's. Thanks in advance.
Fordified is offline
post #2 of 2 Old 10-20-2013, 01:18 AM
I ran Eagle 16X10 rims with 305/70 tires on my 99 250 for 12 years.
No complaints with the rims.
They stuck out past the fenders with a 5-3/4 backspace.
The tire sidewalls bulged about 1-1/4" past the rim.
Even with mudflaps they would spray the mirrors.
Check the load rating for your new rims. Mine were 3520 lb. with a 60 psi pressure limit.
The 305 tires were rated at 2910 lb. at 50 psi.
I did not need a center bushing.
The truck had a 9-1/2 ft. camper with a 3-horse trailer and never had any tire or wheel issues.
I also ran 285/75 on the stock rims for winter. They were real close to the 305 diameter.
XR250R is offline
