non abs hub on a abs truck? abs light on. - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 10-06-2013, 03:53 PM Thread Starter
200x3wheel's Avatar
I just bought an 03 f350 yesterday and noticed it had an abs light on . I asked the guy and he said he blew a wheel bearing on a road trip and whereever he brought it they only had a non abs hub. Well my problem is that where I live I need to get a saftey inspection done on the truck and an abs light is going to be a problem . So my question is , is there a way to put an abs sensor on a non abs hub , I'm thinking no. And if not can I jump the wire out somehow to make the dash light go out or just pull a fuse. I don't want to replace the hub cuz there so expensive. An help would be great thx in advance.
200x3wheel is offline
post #2 of 4 Old 10-06-2013, 03:56 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
If the sensor spot is in the hub you can add the sensor for about 40 bucks
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 4 Old 10-06-2013, 04:00 PM Thread Starter
200x3wheel's Avatar
Ya I guess ill have to pull the wheel and caliper off to take a look.
post #4 of 4 Old 10-07-2013, 02:19 AM
JSchuricht's Avatar
The non ABS hub does not have a tone ring for the sensor to pick up. The sensor cost almost as much as the hub if it needs to be replaced. The only way I can think of to disable it is to flash the PCM to a rear wheel ABS setup.
JSchuricht is offline
