Will 35's Fit? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 15 Old 10-02-2013, 01:26 PM Thread Starter
Ford:Excelling all others's Avatar
Will 35's Fit?
I have a stock 2013 F350 King Ranch 4x4 Diesel. Will 35's fit? If not how much lift do i need?
Ford:Excelling all others is offline
post #2 of 15 Old 10-02-2013, 02:38 PM Thread Starter
Anyone????
post #3 of 15 Old 10-02-2013, 02:45 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
should fit with a 2-3 inch leveling kit.
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #4 of 15 Old 10-03-2013, 03:30 AM
Yes they will fit. I have nittos on my 2013 w/ 20's . It looks great and didnt require a leveling kit
Alamo707 is offline
post #5 of 15 Old 10-03-2013, 04:44 AM Thread Starter
You don't rub at all? Do you have pictures?
Sent from AutoGuide.com App
Living the dream
post #6 of 15 Old 10-03-2013, 06:48 PM
hard to see but these are 295/65 20 which are basically 35" totally stock height suspension no rub
BeerCan is offline
post #7 of 15 Old 10-03-2013, 07:09 PM
brdgraf's Avatar
35 toyos no rub and no lift. Have the 295 nittos on now and they don't rub either
2012 F-250 6.7L Lariat CC White platinum and pale adobe two tone
AFE Pro dry intake
Recon smoked cab running lights w/ amber LED's
Recon smoked mirror side lenses w/ amber LED's
brdgraf is offline
post #8 of 15 Old 10-05-2013, 06:00 PM
305 55 20?
What about 305's? Will they fit on stock 20" rim and stock suspension without rubbing?? Getting ready to go on a Moose hunt and want a bigger tire.
AkweFord12 is offline
post #9 of 15 Old 10-06-2013, 07:39 PM
brdgraf's Avatar
I'm not real sure about that. If they r much taller than 35 and wider than 12.50 u may rub some. 295 fits fine but doesn't have lot of clearance left to play with
AFE Pro dry intake
brdgraf is offline
post #10 of 15 Old 10-07-2013, 05:50 PM
OK, thanks for the reply. I like the 295 look...
