Steering tire sugesstions - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 09-23-2013, 01:57 PM Thread Starter
69superbee's Avatar
Needing some input here. I've got a 2000 F-350 CC Dually 4x4, have 235-85/16's BFG All Terr. TA/KO's all around. I'm not getting the life I would expect to see on the fronts,and no I'm not rotating them which maybe some of the problem.
Got the feeling that they may be a bit soft for the front, what are you guys running and are you getting good life out of them? Thanks for any help you can give me.
69superbee is offline
post #2 of 7 Old 09-23-2013, 02:12 PM
SuperCrutyPS's Avatar
Quoted: 296 Post(s)
Garage
I don't have a dually (See sig), but I'm running BFG TA KOs. I rotate them every 5000 miles. About the time they get to the rotation interval, the front ones get noisy.
I would recommend rotating them. By rotating them to a non-steering position at the correct intervals, gives them a break, if you will, from the wear/tear they get up front.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #3 of 7 Old 09-25-2013, 10:55 AM
XPLOSIV's Avatar
Rotation for a dually is front to front and rear to rear. Just swapping sides. No front crossed to back and back to front. Just the way it is on life of the wheels.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #4 of 7 Old 09-25-2013, 06:57 PM
Are these load rate D or E tires? D tires are softer than E rated tires.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #5 of 7 Old 09-25-2013, 08:05 PM Thread Starter
69superbee's Avatar
They are E's. Didn't think going front side to side would make any difference but I sure will try it.
post #6 of 7 Old 09-25-2013, 08:53 PM
I didn't know this. When I owned a dually they would swap my fronts to the back.
claws314 is offline
post #7 of 7 Old 09-26-2013, 05:38 AM
XPLOSIV's Avatar
Maybe if you have all 6 wheels that are steel. Mine would look kinda funny with the steel wheels up front and a set of billet wheels turned inside out on the rear. Also, if you look in the owners manual that's what it says. Sucks for wear, but is what it is.
08 F450 CCLB 4.30's
XPLOSIV is offline
