2 questions - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 09-23-2013, 12:50 PM Thread Starter
2 questions
i have an 03 f250 6.0 crew cab lariat with 4in suspen. lift and i have a goose neck. i want to get a 3 in body lift. what will i have to do to get the goose neck to work? it is an under the bed gooseneck. thanks for the help also does anyone have an idea of what size tires this would fit and what outset i would need so it doesnt rub?
ddlwfo94 is offline
post #2 of 4 Old 09-23-2013, 12:54 PM
Raul@Stealth Automotive's Avatar
in almost 8 years doing this i have only seen 1 person put a body lift on their truck.. its a bad idea... you have a lot of things in the engine compartment attached to the body so you will have to relocate everything in order to install one...
do yourself a favor and just get a 6" kit...
Raul@Stealth Automotive is offline
post #3 of 4 Old 09-23-2013, 12:59 PM Thread Starter
who has a good 6in or 8 in kit then that is under 1000 and still good
ddlwfo94 is offline
post #4 of 4 Old 09-23-2013, 01:02 PM
under 1k? doubt their is anyone good... if your willing to go up a few hundred dollars you can do a procomp kit.. http://stealth-automotive.com/index....product_id=897
