35's or 37's - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 36 Old 09-23-2013, 07:27 AM Thread Starter
35's or 37's
Doing a 6 inch lift on my 2012 F-250, should I do the 35x12.5's or the 37x13.5's??
Thought? Post pics if you have them. Thanks!
SHearn is offline
post #2 of 36 Old 09-23-2013, 07:43 AM
ngaraiderman's Avatar
35's fit with a leveling kit and I think wouldn't look right with a 6" so my vote is 37's
ngaraiderman is offline
post #3 of 36 Old 09-23-2013, 01:52 PM
38s i have 36s with a 4in lift but mine is an 03
ddlwfo94 is offline
post #4 of 36 Old 09-24-2013, 10:12 AM
wired1's Avatar
37's will fit and look better on a 6" but stay with a 9" wide wheel with 0 offset or a + offset to make them fit.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #5 of 36 Old 10-02-2013, 05:09 AM
scummins's Avatar
I have 37s on a 10 inch wide wheel -24 offset. No rub. That being said, I went from a 34.5" terra grappler to the 37x13.5 Toyo mt and am unpleasantly surprised by how loud they are and how much horsepower they suck up. Feels like I lost 100 hp. And I dropped 2 mpg. I'd go with an at if you go 37.
11 Lariat
6" lift, 37's, Moto Metals, H&S, SPE, JL SPL2K
scummins is offline
post #6 of 36 Old 10-02-2013, 05:52 PM
Gapowerstroke's Avatar
wont matter if it's a mud terrain or all terrain, if you go to a bigger larger diameter and wider wheel and tire you will loose hp and mpg's, the increase in weight, overall final drive ratio and rolling resistance will have a negative effect on all of those. Lower ring and pinion gears will help some but cant overcome the added weight and rolling resistance.
06' F250 CC SR SB FX4 AT
Studs,S&B CAI, MRBP 4" exhaust 3.5" down pipe, SCT LIVEWIRE TS, Tuned by Eric (xtreme street and race), Innovative Inductive and Performance FICM Tunes, blue spring upgrade, 2.5" Carli Leveling kit, 18x9 BMF Novakane Death Metal with 35x12.50 Toyo MT's 3:73 gears.
Gapowerstroke is offline
post #7 of 36 Old 10-03-2013, 02:43 AM
Quoted: 18 Post(s)
Definitely 37's will fit and look right on a 6" lift.
truckfan is offline
post #8 of 36 Old 10-03-2013, 03:21 AM
deanbrada's Avatar
Go with the 37x12.50. Perfect look for a 11-14 with 6" lift.
deanbrada is offline
post #9 of 36 Old 10-07-2013, 06:23 PM
Gburow's Avatar
35's or 37's-imageuploadedbyautoguide1381195295.596950.jpg35's or 37's-imageuploadedbyautoguide1381195310.556459.jpgim running a 6" with 37x13.5 on a 20x10 -24 offset and have zero rubbing
Sent from AutoGuide.com App
Gburow is offline
post #10 of 36 Old 10-08-2013, 04:20 PM
colonel angus's Avatar
Quoted: 2 Post(s)
2005 37's with a 9" wheel + 18 offset with a 6" lift is the exact fit as stock with stock ride height and tires....
I've had numerous sets of 35's with ICON 4.5" and on my 2nd set of 37's with same ICON 4.5" + 2" Spacer and 5" Rear blocks.
PM if you want pictures.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
