2" wheel spacers? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 10 Old 09-14-2013, 08:55 PM Thread Starter
2" wheel spacers?
are these 2 inch wheel spacers dangerous to run? I have always heard the the small spacers that go between the hub and wheel are dangerous but these use 8 lugs to hold the spacer to the hub then 8 to hold the wheel to spacer. Just having a hard time finding the right offset wheel.
PowerstrokeAaron is offline
post #2 of 10 Old 09-14-2013, 09:23 PM
BIG Laing's Avatar
What wheels and offset are you wanting?
Quality hub centric and wheel centric spacers are $600.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 10 Old 09-15-2013, 02:44 PM Thread Starter
i wanted 20x12 fuel hostage but the -44 offset will rub my leafs I am running 38.5x14.50, I think with 2" spacers they will stick out too far. If I get the 20x10 -24 offset it would still rub but then I was thinking i could use the spacers and they wouldnt stick out too far. I have a 10.5" lift btw. Any suggestions? Right now I have 20x11 -24 MKW M19's and they rub my leafs. I had 37x12.50's with no rubbing, then got 37x13.50 and they rubbed. Now with the 38.5x14.50 they def are rubbing more. Plus i think it would look better with the wheels sticking out a little more. What offset is everyone running with the big lifts it seems like these are the most negative ones I can find.
post #4 of 10 Old 09-15-2013, 03:24 PM
BIG Laing's Avatar
Might be cheaper/better to convert to 05+ coil suspension.
Have you tried calling fuel, and seeing if they do custom wheels?
post #5 of 10 Old 09-16-2013, 09:20 AM
Quoted: 3 Post(s)
Get a quality set of spacers from Cary or Fred and call it a day. The leaf spring front ends can only accommodate 37's without rubbing. I have deep dish 20x12 and 40x15.50 and i don't rub. I'm running a set of spacers from Cary, hub-centric and wheel-centric
11 F250 CCSB King Ranch
Tyrant tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 4.5" PMF block, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #6 of 10 Old 09-16-2013, 02:09 PM Thread Starter
what offset wheels are you running and how big are the spacers?
post #7 of 10 Old 09-17-2013, 02:08 AM
Quoted: 3 Post(s)
-44 and 2"
01 Ex 7.3l Limited
06 headlights
post #8 of 10 Old 09-17-2013, 08:21 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We sell spacers..These are U.S. Alcoa 6061t6 billet aluminum, Lifetime warrantee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
2" spacers will work without needing to cut off your existing wheel studs
We can get you 1.25-1.5" spacers but you will have to trim the studs shorter. But the back space with then be 4.5" and the rim will set like factory.
CT Performance, Inc. is offline
post #9 of 10 Old 09-20-2013, 08:33 PM Thread Starter
how much for the 1.25" spacers? and then what lug nuts do you use? I have the splined wheel locks now just use those to hold the wheel to spacer then what holds spacer to hub? stock acorns?
post #10 of 10 Old 09-21-2013, 06:20 AM
Quoted: 3 Post(s)
We provide new lugs to install the spacers.
I'll PM you prices.
