Soft/sinking brake pedal - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 9 Old 09-13-2013, 08:11 PM Thread Starter
sputnik801's Avatar
Quoted: 3 Post(s)
97 F350. NEW rear drums & shoes. front pads/rotors less than 8 months old. Bled the crap out of brakes and installed a new master cylinder. I still have a squishy pedal, which when pressed hard, sinks almost to the floor. When pedal goes down, the brakes still hold. I've seen one post where the member put the truck on a sever down angle, nose down and bled brakes. This angle caused the master cylinder to be level allowing the air to finally escape.
Anybody have this issue? I'm going to try to bleed them Monday after my weekend night shifts.....Tired of this situation.
Also - there is no way the vacuum booster can cause this issue? I know it can cause brakes to apply if the internal spring breaks, but I see no way it can cause this issue..
sputnik801 is offline
post #2 of 9 Old 09-13-2013, 09:43 PM
Quoted: 858 Post(s)
Feedback Score: 3 reviews
I think you have a bad reman Master cylinder.
Booster wouldnt make any difference with your symptoms. Did you bench bleed the MC?
Corey@CNCFAB is offline
post #3 of 9 Old 09-13-2013, 10:04 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Might have bench bleed the master cylinder wrong... Or not at all.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 9 Old 09-14-2013, 02:59 PM Thread Starter
sputnik801's Avatar
Quoted: 3 Post(s)
Bench bleed mc real well. Symptoms are EXACTLY as they were with old mc as they are with NEW (not reman) mc. After doing more reading I'm leaning to the ABS sensor. It does it ONLY when running.
Thanks!
post #5 of 9 Old 05-22-2014, 06:21 PM
Did you resolve the issue? I am having the same problem.
bigblue91 is offline
post #6 of 9 Old 03-23-2016, 04:12 AM
iv got same problem, bleed brakes many times fluid comes out hard with no air, replaced master cylinder , still did same thing, brakes build up when not running, also heard that this abs valve is the problem, going to bypass like every one else does to see if thats the problem ,
BigRobDog is offline
post #7 of 9 Old 03-25-2016, 11:25 PM Thread Starter
sputnik801's Avatar
Quoted: 3 Post(s)
I've researched it - it is the vacuum booster. There is a non-fading booster, part number F5TZ-2005-CA. At around 200 bucks, I'll deal with the sinking pedal unless it becomes a problem!
post #8 of 9 Old 07-26-2016, 02:00 PM
So...I have the same problem, did any of you find a resolution??
Sent from my iPhone using Tapatalk
dbanksls01 is offline
post #9 of 9 Old 08-02-2016, 05:29 PM
...and the same problem on mine. Replaced and bench bled the NEW MC. It was rock hard until I started the engine.
Curious, what led Sputnik to conclude it is the Master Cylinder?
When I swapped mine out, there is a hexagonal valve body on the rear port that has a small nylon and rubber diaphram valve. I noted that the nylon "post" in the center was chewed up. Snipped of the mutilated tip and reinstalled it. Any link between this valve and our problem? Anyone?
Thanks!
acdiesel is offline
