Front end crooked??? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 7 Old 09-07-2013, 06:59 PM Thread Starter
I got a perplexing problem. I was installing mud flaps on my 2012 f-350 and completed the passenger side when I went to install the drivers side the tire was a full inch back (closer to the cab) than the passenger side. This made it impossible for a mud flap to go there without rubbing. I have bushwacker fender flares so thought maybe something was wrong there but I measured center of axle to a point on the frame and the drivers side was a full inch closer.
Is his normal??? I have never hit anything or been in a accident. So not sure what to do.
Wylie61 is offline
post #2 of 7 Old 09-07-2013, 07:13 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
my 2000 is the same way, i noticed the difference yesterday on the driver side
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 7 Old 09-07-2013, 08:33 PM
Term3's Avatar
A bud found his '04 truck was like that as his would pull to the right under heavy breaking from the day he bought it new. He had alignment after alignment done before he noticed that the drivers side axle was working its way to the rear because that side tire started to rub in turns. He started taking things apart and found that the spring pack bolt head that centers it with the axle had sheared off and the axle was slowly working its way down the spring pack.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #4 of 7 Old 09-07-2013, 10:54 PM
schlutzer's Avatar
Quoted: 18 Post(s)
X2 I've seen this before on a rear axe in my old ranger after installing lift springs and using an impact on the centre bolt.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #5 of 7 Old 09-07-2013, 11:17 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
The OP is talking about the front end and 05 and up have coil springs, not leaf springs.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 7 Old 09-07-2013, 11:27 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Lol well.... Shows how well I read.
I guess in that case he needs to be looking at the links and their mounts to see if anything is not right. You wouldn't expect anything to be worn on a such a new truck but who knows
post #7 of 7 Old 09-08-2013, 04:34 AM
Term3's Avatar
LOL. Me too. Most of my buds have leaf springs hard to think about there's actually coil fronts out there sometimes. I'd think a bushing has split or got oil on it enough to soften would be my guess if nothing got bent. Could put in some polyurethane bushings that will not flex as much.
Term3 is offline
