Anyone help with fitment...possible pics? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 09-04-2013, 08:58 AM Thread Starter
I have a 2005 F250 all stock...I am wanting to get a set of 18x9 Monster XD's with a -12 offset with a set of 33" tires (possibly but not necesarily 12.50 wide). Will this work on the truck. I am looking for a little wider stance so to me this sounds good. If I have to throw a 2" leveling kit on the front, I will. Just hoping someone has this combo on a stock or almost stock truck so I can see what it looks like. I called around and guys are telling me -12 offset it too much while others are telling me it will be fine.
Can someone set the record straight for me. Thanks
mcflyin is offline
post #2 of 4 Old 09-04-2013, 07:01 PM
Fox Hunt's Avatar
Quoted: 29 Post(s)
I have 20x9 -12 wheels that I have yet to put on and am going for the same look. With 33s I think you should be good, possibly a leveling kit needed. 35s rub sometimes even with the leveling kit. From all my research we should be good
Sent from AutoGuide.com App
2006 F-350 CCSB Lariat
MBRP 4" Exhaust, ARPs, Barder Stage 2 turbo, S&B CAI, TSD SPD, Warren Competition transmission, Edge CTS, Coolant Filter, High Idle Mod, CCV Mod, Zoodad, Newton Leveling kit, Fuel Mavericks 20x9 , Pioneer DVD head-unit, JL Stealthbox and JL Slash 500/1v2 amp
Future Mods:
Injectors and Driven Diesel RR
-Alex
Fox Hunt is offline
post #3 of 4 Old 09-09-2013, 10:47 AM
BWWilliams's Avatar
i had 35 12.5s with stock 18s on my truck with no lift at all and didnt rub anywhere that caused a problem. they touched the radius arms just a tiny bit at the lock but nothing that caused damage.
'06 F250 Lariat 4x4
Ex/cab LB, ARP Studs, 4in turbo back, SCT LW TS box tunes, Ford HG, Egr delete w/new up pipe, Blue spring kit, wicked wheel 2/Stock turbo, Stock injectors
Updated: oil cooler, HPOP fitting, stand pipes, trubo feed/drain lines and all that fun stuff
onboard air system/semi horns
High idle mod
4in rad arm lift
37x13.50R17 toyos
Coming soon: PHP tuned FICM/ ECM tunes, custom front/rear bumpers, custom trac bars
BWWilliams is offline
post #4 of 4 Old 09-09-2013, 10:54 AM
BWWilliams's Avatar
sorry but this is the best pic i have right now
'06 F250 Lariat 4x4
High idle mod
4in rad arm lift
37x13.50R17 toyos
