Need to ballance a shaved rim for a 08 F-450 Dulley with 11R22.5 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 09-03-2013, 01:47 PM Thread Starter
I have a 2008 Ford F-450 Dulley with shaved 22.5 Alcoa Wheels. but I need to get the wheels Balanced.and I can't find anyone who can with the wheel shaved.
nuck321 is offline
post #2 of 4 Old 09-04-2013, 10:23 AM
5fifty's Avatar
I wouldn't see why a rim and tire couldnt be balanced regardless if it is shaved unless the center has been milled out for the adapters. You can install balance media through you valve stem and you can get Centramtic balancers that bolt on behind the rim that balance as you drive.
An RV dealership or semi shop should be able to help. Most Tire Kingdom and general passenger tire shops can't do it.
2005 F-550 4x4 22.5's
Kelderman Air Ride
Bulletproof Diesel Remote Oil Cooler W/F550 Cooler
Bulletproof Diesel Billet Water Pump
Bulletproof Diesel Radiator
Dieselsite Wicked Wheel, Dieselsite Coolant Filter Kit
Warren Diesel 155/30, Bluespring Mod, 6.4 Banjo,
Updated STC, Turbo Feed and Drain Tubes,
PMM EGR Delete
SCT Tuner, Edge Insight w/EGT, Fuel and Oil Pressure
Tuned By MATT @ Gearhead Automotive Performance
5fifty is offline
post #3 of 4 Old 09-06-2013, 06:28 PM
not sure what a shaved wheel is, is it when the lip is machined for clearance? No idea if thats why but any tire shop can static balance a wheel with stick on weights anywhere on the inside face of the wheel where it wont hit the caliper.
PowerstrokeAaron is offline
post #4 of 4 Old 09-06-2013, 07:50 PM
5fifty's Avatar
Again a good reason to go with the balance media or something like balance masters.
My 22.5's wont be shaved and I am going with the Balance Masters myself.
Kelderman Air Ride
PMM EGR Delete
5fifty is offline
