16.5" replacing 16" Wheels? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 08-25-2013, 08:01 AM Thread Starter
Good morning,
I have an opportunity to get a different set of wheels with very good condition skins. They are currently on an '85 F250.
Set of four: 33 x 12.5 16.5 W/rims FROM A 1985 F250. Load range D. for sale locally.
My '94 currently has steel wheels with a cover on them. Tires are: 235R16's
Naturally 8 lug. I found out that the bolt pattern is probably 8 on 6.5 ?
I also found that wheel size is rated - 16" "Minimum".
Does that mean that F250ís can upsize wheels, but bolt patterns remain same?
So long story shorter, will those referenced wheels work on my rig?
I'm oh so new to most things mechanical, but have a desire to learn and turn my own wrench. And have no clue about wheels and tires.
The 33 designation is what? Is that the same as the designation as in the 1st set of say: Lt235?
I presume this a bigger/taller tire.
If so, will there be rubbing issues if truck is stock?
Is there somewhere I can look, unless someone here does good explanation to help my understanding of this subject matter, to maybe get the differences of these two sizes? Mine vs. the set in question.
Thanks for any info that helps me learn something. Sorry for what may be stupid questions
Truck #1 - 1996 F250 PSD 4x4 w/4" Lift - AFE Air Intake, Rebuilt Modded Turbo, TS 6 Position Performance Chip, Rebuilt Stage I Injectors, AutoMeter Phantom II 3 Pod Pillar, Rebuilt/Modded E40D, Procomp ProRunners, After Market RKE w/Remote Start and a Smelly Tree on the rear view!.
Truck #2 - 1994 F250 XLT 7.3L Turbo (IDI) Pre-PSD, SuperCab, Banks 3" DP, 4" Pipe to a 5" Double Wall Chromed Tip. DIY Air Intake with 6637, BB Injectors, Alloy ProComp Classics, Long Bed
damedic is offline
post #2 of 3 Old 08-25-2013, 04:38 PM
1. '85 and '94 Ford trucks are more or less the same, if it fits on one, it will fit on the other.
2. In your tire size: 235R16, you left out the aspect ratio that is very important to the size of the tire.
235: Section width of the tire: ie from sidewall buldge to sidewall buldge.
75: Aspect ratio, as in the amount of sidewall height in relation to the section witdth, in a percentage.
R: radial
16: rim diameter.
LT: Light Truck
33x12.50-16.5:
33: overal diameter
12.50: section width
16.5 rim diameter.
Your truck has the very common 8x6.5 lug pattern. All GM, Dodge, and pre 1999 Ford wheels have that lug pattern.
Try playing with this web site, it should help understanding tire sizes.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #3 of 3 Old 08-25-2013, 07:40 PM Thread Starter
Good evening, Karls-
...and thanks for the reply, & I appreciate the link!
Yeah, my bad - the correct spec's of my tire on my IDI are:
LT235/85R16
So, now over to that website and do some pokin' around and see if I learn something. then I'll be a little smarter when it comes to tires and wheels.
Then if a deal comes along, I can put them on my 94. Like the one asked about. Off to find out if they might work??
Thanks again.
damedic is offline
